Lifters won't spin..440 #813036
09/23/10 11:20 PM
09/23/10 11:20 PM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Hey Guys,
I installed the MP .528 in my 440. It had been sitting around for a few years so it had some very minor surface rust. I used a 2000 grit sand-sponge to remove it. I have all of the valvetrain installed and the intake is off. I wanted to make sure all of the lifters are spinning. I have two that are barely and almost not at all spinning. Bad lifter? Bad cam? Bad lifter bore? I'm open to any ideas?
Michael
Re: Lifters won't spin..440 [Re: SILVER67] #813037
09/23/10 11:23 PM
09/23/10 11:23 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Do they spin EZ in the bores ? ...good crowns on the lifter faces ?
Re: Lifters won't spin..440 [Re: SILVER67] #813038
09/23/10 11:25 PM
09/23/10 11:25 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Unused cam? Try swapping lifters around until you get them all to spin.
Damon
Re: Lifters won't spin..440 [Re: dOoC] #813039
09/23/10 11:31 PM
09/23/10 11:31 PM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Yea lifter face seems okay. Spin freely in the bores too. I haven't measure them though. Is that okay to keep mixing them around until I get them all to spin?
Michael
Re: Lifters won't spin..440 [Re: SILVER67] #813040
09/23/10 11:41 PM
09/23/10 11:41 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Call me at the shop Saturday, and stop over and grab a couple of my Crower lifters....try them. Since you already have swapped some lifters, not sure its going to help, but try another manufacter first.Since its the same bores that its doing it on, I am suspect there, but try these first to save the next step.Bring your two bad lifters, I want to look/measure them.
RIP Monte Smith
Re: Lifters won't spin..440 [Re: SILVER67] #813041
09/23/10 11:42 PM
09/23/10 11:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Michael
Fine if its a new cam and lifters
Re: Lifters won't spin..440 [Re: SILVER67] #813042
09/23/10 11:48 PM
09/23/10 11:48 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Michael
How much spring pressure do you have ?
Re: Lifters won't spin..440 [Re: CompWedgeEngines] #813043
09/24/10 12:02 AM
09/24/10 12:02 AM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
Sure will ! Probably call after 12:00.
Re: Lifters won't spin..440 [Re: dOoC] #813044
09/24/10 12:03 AM
09/24/10 12:03 AM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
OOTB Eddy RPM heads springs........
Re: Lifters won't spin..440 [Re: SILVER67] #813045
09/24/10 12:35 AM
09/24/10 12:35 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If that cam kit is a few years old you might have got a couple/several bad lifters. Wasn't there a lot of QC issues with the offshore lifters after Johnson Tappet went belly up a few years ago? Improper crowns etc. If those 2 Crower lifters will spin I think I would spring for a set of 16.
Kevin
Re: Lifters won't spin..440 [Re: Twostick] #813046
09/24/10 12:39 AM
09/24/10 12:39 AM
Liverpool, NY
SILVER67 Offline OP
SILVER67  Offline OP
Liverpool, NY
I believe the tag on the Mopar box said the Cam and Lifters are from 2003....... Pretty sure I bought it in 2004
I'd be tickled pink if I just got some bad lifters. Beats having a bad lifter bore I would think !
Michael
Re: Lifters won't spin..440 [Re: Twostick] #813047
09/24/10 01:18 AM
09/24/10 01:18 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
Kevin
Good call without any doubt that's the first thing to check. The crowns were off center and lifters didn't turn
home of the
Sox and Martin Hemi Duster
Re: Lifters won't spin..440 [Re: HEMIFRED] #813048
09/24/10 01:44 AM
09/24/10 01:44 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Thanx Fred I'm pretty sure I saw that on here a few years ago. I can remember stuff like that but I can't find my car keys.
IMHO this why 90+% of flat tappet cams fail. Lifters no spin for what ever reason.
Kevin
Re: Lifters won't spin..440 [Re: Twostick] #813049
09/24/10 03:17 AM
09/24/10 03:17 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
I think if you placed the lifters face to face you would not be able to see the crown. good lifters always have the edges show light. the NASCAR guys have a mahcine that puts the crown back and polishes the lifter face
home of the
Re: Lifters won't spin..440 [Re: SILVER67] #813050
09/24/10 04:30 AM
09/24/10 04:30 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
first try very worn old used lifter,any type. if still binds its ovaled/worn/funky lifter bore,hate to say it but, ive honed lifter bores in car complete runing motor intake off with drill motor and wheel cylinder hone. after pull pan plug 1 can brake clean, then flushed with 5 quarts new oil, they will spin like a champ then
MOPAR OR NO CAR
Re: Lifters won't spin..440 [Re: hemigod426] #813051
09/24/10 07:45 AM
09/24/10 07:45 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
with trhe dating he supplied my first concern is the lifters being junk. i can remember dozens of camshafts biting the bullet back then
home of the
Re: Lifters won't spin..440 [Re: HEMIFRED] #813052
09/24/10 08:10 AM
09/24/10 08:10 AM
gregsdart Offline
gregsdart  Offline
Sometimes it is too fine of a finish on the lifter base. Take some 500 grit sand paper, put it in the palm of your hand and push the base of the offending lifter into it, rotating the lifter to take the shine off. Clean, reinstall and check again. Works great, I,ve had no failures doing this.
