Page 1 of 3 1 2 3
What are the fastest SB mopar stockers ( with carbs ) #810316
09/21/10 01:35 PM
09/21/10 01:35 PM
Big Island ,VA
JC Childress Offline OP
Big Island ,VA
Just curious what some the fastest small block Mopar stockers are ?
How would a 71 340 Duster do ?
Just thinking out loud and looking for some input.
Thanks for any info.
J.C. Childress (434) 665-9541
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: JC Childress] #810317
09/21/10 01:52 PM
09/21/10 01:52 PM
NHRA,in all of its of its wisdom, has raised the HP rating in stock on all of the 340 motors high enough that a lot of the better 340 racers (and 360 and 318) have not raced them do to raising the HP rating on those motors which raises the cars up in class or cause them to add weight to stay in the class they ran it in. To answer your question the 1971 340 was hit the most next to the 1970 T/A Challenger six pak motors One thing you need to keep in mind when deciding to race in NHRA stock is unless your running another car in the same class your bracket racing, the faster cars(run more under the NHRA class index) get to dial under more than the same but slower class car can I ran a NHRA stocker off and on for a lot of years, the only time I got to race a car in the same class was at the races where they held class run offs. I never ran a car in the same class on Sunday in over 15 years of running
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: JC Childress] #810318
09/21/10 01:53 PM
09/21/10 01:53 PM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
The fastest are the new Challengers they are really flying. A lot of guys run the Dusters in F/SA and G/SA which is usually a 10.80-11.20 car. My Volare is a H/SA car and has to weigh 3490 for NHRA and has run 11.20's with a 360.
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: JC Childress] #810319
09/21/10 02:08 PM
09/21/10 02:08 PM
mi
V
vcummins Offline
vcummins  Offline
V
mi
J.C Its to bad IHRA stop running top stock. It was A lot of fun. I think you were building your car for top stock weren't you ?
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: vcummins] #810320
09/21/10 04:34 PM
09/21/10 04:34 PM
Big Island ,VA
Big Island ,VA
It was built specially for Top Stock but since that was a flop, I am kicking around different ideas. I love stock and super stock, just dont have all the funds I need to get it all going right now. In due time I guess.....Rome wasnt built in a day ! LOL....
I think it would make a killer stocker with a few changes.Just looking for ideas and suggestions.
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: JC Childress] #810321
09/21/10 04:46 PM
09/21/10 04:46 PM
Locomotion Online content
Locomotion  Online Content
Overall ET or under the index?
A 340-6 Challenger T/A had the C/SA record in the 10.30's a while back and I believe and I've seen '71 340 A-bodies running around mid-10's in ideal conditions.
But as Cab pointed out, they got hit with with more HP.
Under the index would take some research, including watching all qualifying sheets. But there is no telling how much $$$ has gone into any of the faster combos.
What body or bodies do you have to work with?
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: Locomotion] #810322
09/22/10 09:46 AM
09/22/10 09:46 AM
Big Island ,VA
Big Island ,VA
All I have is 2 Dusters. I meant fastest as far as overall ET, not how far under the index they can go.
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: JC Childress] #810323
09/22/10 10:19 PM
09/22/10 10:19 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
the reason this is relevant..is...its the only class of racing your gonna find Truely "stock"
so to find a fast stock car time...you have to factor if against the index..
alot of cars are capable of much faster...
if i was gonna take a stab at a number id say. 10.80s off the bat...
now when you add to the engine capable of that et..
gun drilled axles, alloy drive shafts, seriously worked over transmissions...a very well sourced chassis...with relative 60ft times...
i can see another .4 -.5 off of the 10.80 number
id put it about right there...
(stab a real cam in the car and it would blow that number out of the water..but i digress)
i feel a 360 on paper should get it done over a 340...but some of dem 340 cars are scootin...
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: JC Childress] #810324
09/22/10 10:30 PM
09/22/10 10:30 PM
The model year of the Dusters limit your options also, unless you run IHRA-only Stock GT or Crate Motor which allow non-OEM engines in the car used. But for regular Stockers, you have to use only the engines that were available in the model year car being used. The horsepower factors determine what class you end up and the index to run under. The hard part is figuring out which has the most favorable/underfactored HP rating. But the Mopar combos have been worked on for decades and the fastest ones are pretty fast.
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: Locomotion] #810325
09/23/10 11:28 AM
09/23/10 11:28 AM
Big Island ,VA
Big Island ,VA
It may not be the ideal combo, but I'm liking the 71' hi-comp 340 combination in my Duster as a D/SA car.
I have been talking to Bruce at Parsons and Myers and he has been very helpful as well as a guy in Missouri named Brad Van Lant ( last name is prolly wrong, but close..). They are both very sharp on the small block Mopar stockers.
I'm always open to any and all suggestions.
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: JC Childress] #810326
09/23/10 11:35 AM
09/23/10 11:35 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Not alot of in-depth information but some interesting reading on the car about some details.
LINK HERE
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: DJVCuda] #810327
09/23/10 11:52 AM
09/23/10 11:52 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i see they don't have to run the correct year t-quad? i wonder why they leave the choke plate and rods on when if removed can pick up 50 cfm's or so
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: ademon] #810328
09/23/10 11:54 AM
09/23/10 11:54 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I'd refer you to the rule book ( NHRA ) as I dont know all the ins and outs of the class... it is very specific in some areas ( carb base gaskets , for example)
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: ademon] #810329
09/23/10 01:00 PM
09/23/10 01:00 PM
Throttle bores and venturi have to be the same size as OEM.
Otherwise, it's the rules! In IHRA Crate Motor Stock, small blocks are allowed a 750 Holley and big blocks an 850 Holley. But they have to retain the choke tower and plate also with no additional mods (besides jets, squirters, pump cams, etc.).
J.C., Yes, the fast Stock racers and builders are the most knowledgable.
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: Locomotion] #810330
09/23/10 01:17 PM
09/23/10 01:17 PM
South Dakota
hotairballoonpilot Offline
South Dakota
If you are going to work with Brad Van Lant all I can say is watch out! and be carefull. He will lets say make you need to change your pants. He knows his way around a small block mopar. Seen his cars flat run, He use to live in Luverne Minnesota and I belive he lives around the ozarks now. last I heard he was working for a guy that ran a mechanic shop around the lakes that use to live in Sioux Falls. Can't remember his name.
Good luck.
Contact Me about AMD Prices
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: Locomotion] #810331
09/23/10 01:39 PM
09/23/10 01:39 PM
Big Island ,VA
Big Island ,VA
I'm pretty familiar with the rules, just fishing for ideas and suggestions.
Nothing personal Myron, but the crate motor class isnt my cup of tea. You are awesome at it and I admire you and what you've accomplished, so please dont take it the wrong way, it just doesnt interest me.
Anything I do is based on a small budget. If I was able to run this deal, it would be with a production 340 block, and maybe some X heads. Anyone have any x heads ?
I may also talk to Bub Whitaker, as I know his stuff runs great also.
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: JC Childress] #810332
09/23/10 05:11 PM
09/23/10 05:11 PM
No problem J.C., just putting out options.
Sometimes I wish I could have the flexibilty of runnibng a "regular" Stocker. But the CM classes are most affordable for me.
As for heads, don't make up your mind prematurely. Most engines have some options that may work better. The engine builders mentioned will know.
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: Locomotion] #810333
09/23/10 05:58 PM
09/23/10 05:58 PM
Kansas City Metro
mbogina Offline
mbogina  Offline
Kansas City Metro
Brad VanLant's 71 340 Duster is awesome, I have seen it run high 10.40's/50's in E/SA trim, I am sure he could run even quicker if he wished. Very knowledgable with this combo. Prior to the 340 Duster, he ran a 440-6 Challenger in B/SA.
Be a Rebel- Break the Laws of Physics!
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: JC Childress] #810334
09/23/10 06:02 PM
09/23/10 06:02 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have a complete X head 340 core motor
Re: What are the fastest SB mopar stockers ( with carbs ) [Re: Quicktree] #810335
09/23/10 08:12 PM
09/23/10 08:12 PM
MN
5343stk Offline
5343stk  Offline
MN
Speaking from a little experience, Brad Van Lant is the best in the country in regards to small block mopars.
I have won F/SA at Indy the last two years with his power under the hood. Without his knowledge and help it wouldn't have been possible.
James Findell 5343 Stock 1973 Plymouth Duster 340 10.67 @ 124
Page 1 of 3 1 2 3
