Dip Stick Install HELP #798173
09/10/10 07:45 PM
09/10/10 07:45 PM
Toronto Ontario
Butt Ugly Offline OP
Toronto Ontario
Pulled out the tube with the stick earlier today.
How do you re-seat that puppy ?? There is a small wire looking ring on block end of the tube ?
Thanks in Advance
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
Re: Dip Stick Install HELP [Re: Butt Ugly] #798174
09/10/10 08:17 PM
09/10/10 08:17 PM
slip an open end wrench on it and tap that to seat it and if little room might need a crows foot. I'd clean the tube and carefully spray a bit of starting fluid in the block hole to clean it (it evaporates right out) & possibly expanding the end (slightly) of the tube w your flaring tool so it grips tight in there and loctite it & drive it home.
Re: Dip Stick Install HELP [Re: RapidRobert] #798175
09/10/10 09:22 PM
09/10/10 09:22 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If that ring is at the very bottom of the tube then the tube is broken off at the block. If it is you need to fish the remainder of the old tube out and install a new tube.
Re: Dip Stick Install HELP [Re: stumpy] #798176
09/10/10 09:56 PM
09/10/10 09:56 PM
Toronto Ontario
Toronto Ontario
Not broken, don't think so any way, bottom of tube is flared. Looked again and it's a tight squeeze to get at the block end of the tube ?
Re: Dip Stick Install HELP [Re: Butt Ugly] #798177
09/10/10 10:46 PM
09/10/10 10:46 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Can't you just stick a long screwdriver inside the tube and lightly tap it in?
I'd take some sandpaper and gently round the leading edge of the tube if its reluctant to start.
Re: Dip Stick Install HELP [Re: Neil] #798178
09/11/10 12:29 AM
09/11/10 12:29 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Toward the bottom of the stick there should be a ring and then the stick will be about 1" to 1 1/2" longer. That extra goes into the block. The easiest way is to put a wrench that just fits around the tube against the top of the ring at a right angle and tap on the wrench handle to drive the tube into the block
Re: Dip Stick Install HELP [Re: stumpy] #798179
09/11/10 12:40 AM
09/11/10 12:40 AM
Western Pa
joewhite440 Offline
joewhite440  Offline
Western Pa
I agree with Stumpy. I think the tube is broken off.
Where is the bracket that is welded to the tube and bolts onto the engine mount to hold it in. It should take very little force to slip that tube back in the block and bolt up the bracket to hold it in. Post a picture of what you have left and maybe it will help us help you!
Re: Dip Stick Install HELP [Re: stumpy] #798180
09/11/10 12:47 AM
09/11/10 12:47 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Does the end of your dipstick look like this?? Jimmy!!
[image] http://ep.yimg.com/ca/I/chucker54_2124_6355566 [/image]
Re: Dip Stick Install HELP [Re: 1_WILD_RT] #798181
09/11/10 01:06 AM
09/11/10 01:06 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
There is a specialty tool made for this application. The tool has half of the bottom part open about 3 inches to fit over the tube down to the ring or ridge part. Now the top half of the tool part is like a chisel so you can use a hammer on it to tap the tool, driving the dip stick tube into the block.
1971 HEMI E BODY REGISTRY
Re: Dip Stick Install HELP [Re: hemicar1971] #798182
09/11/10 01:59 AM
09/11/10 01:59 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
If he is saying the end of the tube is flared, and there is a ring at the oil pan rail, I'll throw my bet into the pot that it's broken off.
Re: Dip Stick Install HELP [Re: Pat_Whalen] #798183
09/11/10 02:35 AM
09/11/10 02:35 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
From his description that's what i sounds like to me too.
See the ring around the tube about an inch from the end at the end that goes in the block.
Re: Dip Stick Install HELP [Re: SNK-EYZ] #798184
09/11/10 02:47 AM
09/11/10 02:47 AM
Mesa, AZ
P
Pat_Whalen Offline
super gas
Pat_Whalen  Offline
super gas
P
Mesa, AZ
Here's another picture. Even though it's an RB pan rail and dipstick, that stamped ring is the same on the smallblock tube. When it's stamped, it thins that ring really well and it's usually broken right there.
Re: Dip Stick Install HELP [Re: Pat_Whalen] #798185
09/11/10 08:00 AM
09/11/10 08:00 AM
Toronto Ontario
Toronto Ontario
Thanks all, got me a broken tube.
Re: Dip Stick Install HELP [Re: Butt Ugly] #798186
09/11/10 12:12 PM
09/11/10 12:12 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The first thing to do now is get the old tube end out of the block. Sometimes you can thread a bolt or screw into the tube in the block and pull the broken piece out.
Re: Dip Stick Install HELP [Re: stumpy] #798187
09/11/10 08:19 PM
09/11/10 08:19 PM
Toronto Ontario
Toronto Ontario
Off comes the alt and fuel pump to get at that unit??
