Dip Stick Install HELP
#798173
09/10/10 07:45 PM
09/10/10 07:45 PM
Posts: 1,951 Toronto Ontario
Butt Ugly
Toronto Ontario
Pulled out the tube with the stick earlier today. How do you re-seat that puppy ?? There is a small wire looking ring on block end of the tube ? Thanks in Advance
Faster Horses, Younger Women, Older Wiskey, More Money --- Tom T
Re: Dip Stick Install HELP
[Re: Butt Ugly]
#798174
09/10/10 08:17 PM
09/10/10 08:17 PM
RapidRobert
slip an open end wrench on it and tap that to seat it and if little room might need a crows foot. I'd clean the tube and carefully spray a bit of starting fluid in the block hole to clean it (it evaporates right out) & possibly expanding the end (slightly) of the tube w your flaring tool so it grips tight in there and loctite it & drive it home.
[Re: stumpy]
#798176
09/10/10 09:56 PM
09/10/10 09:56 PM
Butt Ugly
Toronto Ontario
Not broken, don't think so any way, bottom of tube is flared. Looked again and it's a tight squeeze to get at the block end of the tube ?
[Re: 1_WILD_RT]
#798181
09/11/10 01:06 AM
09/11/10 01:06 AM
Posts: 5,122 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
There is a specialty tool made for this application. The tool has half of the bottom part open about 3 inches to fit over the tube down to the ring or ridge part. Now the top half of the tool part is like a chisel so you can use a hammer on it to tap the tool, driving the dip stick tube into the block.
1971 HEMI E BODY REGISTRY
[Re: SNK-EYZ]
#798184
09/11/10 02:47 AM
09/11/10 02:47 AM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
If he is saying the end of the tube is flared, and there is a ring at the oil pan rail, I'll throw my bet into the pot that it's broken off.
From his description that's what i sounds like to me too.
See the ring around the tube about an inch from the end at the end that goes in the block.
Here's another picture. Even though it's an RB pan rail and dipstick, that stamped ring is the same on the smallblock tube. When it's stamped, it thins that ring really well and it's usually broken right there.
[Re: Pat_Whalen]
#798185
09/11/10 08:00 AM
09/11/10 08:00 AM
Butt Ugly
Toronto Ontario
Thanks all, got me a broken tube.
[Re: stumpy]
#798187
09/11/10 08:19 PM
09/11/10 08:19 PM
Butt Ugly
Toronto Ontario
Off comes the alt and fuel pump to get at that unit??
