Tie rod end taper
#755209
07/22/10 01:39 PM
07/22/10 01:39 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
Anyone know what the tie rod bolt taper is on an original 36 tie rod end? Switching to 7 degree taper. Do I have to build up and re ream or is there a sleeve for this?
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
Re: Tie rod end taper
[Re: poorboy]
#755212
07/23/10 04:52 PM
07/23/10 04:52 PM
36PLYM
Lithonia, Ga
I am looking for tie rod bushings as an alternative to welding up and re-tapering. I had to change out the passenger side steering arm, the original hole is the right taper but too big. The steering arm bottoms out and crushes the boot, the nut bottoms out on the thread as well.
[Re: 36PLYM]
#755213
07/23/10 07:08 PM
07/23/10 07:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Somewhere I have stashed an old TRW chassis component spec book. But I wouldn't bet on me being able to find it anytime soon. As for the nut bottoming out, a washer works well as a spacer.
