Tie rod end taper #755209
07/22/10 01:39 PM
07/22/10 01:39 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
Anyone know what the tie rod bolt taper is on an original 36 tie rod end? Switching to 7 degree taper. Do I have to build up and re ream or is there a sleeve for this?
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Tie rod end taper [Re: 36PLYM] #755210
07/22/10 08:38 PM
07/22/10 08:38 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I believe the tie rod tapper on most Mopars is 7 degrees, least the 39 was and it uses the same tie rod end as the mid 70s Dodge 1/2 pickups. When I was messing around with swapping to the rack & pinion steering on my 39, I looked pretty hard for a couple weeks for bushings but didn't find anything close enough. There are a lot of them out there, but most seemed to be either too big or too small for what I needed. I ended up welding the holes in my steering arms shut and drilling them to the correct size and used a die grinder to "fit" the tapper then used the Intrepid tie rod ends. One advantage of welding the hole shut and re-drilling it is you can move the hole to improve your turning diameter, which gets a lot bigger when you go to a r & p.
Why are you looking for tie rod bushings? There were some available for Ford Torinos, Fairlanes, Rancheros and Broncos. Gene
Re: Tie rod end taper [Re: poorboy] #755211
07/22/10 10:00 PM
07/22/10 10:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
it's taper
Don't be the exception.
Re: Tie rod end taper [Re: poorboy] #755212
07/23/10 04:52 PM
07/23/10 04:52 PM
Lithonia, Ga
3
36PLYM Offline OP
36PLYM  Offline OP
Lithonia, Ga
I am looking for tie rod bushings as an alternative to welding up and re-tapering. I had to change out the passenger side steering arm, the original hole is the right taper but too big. The steering arm bottoms out and crushes the boot, the nut bottoms out on the thread as well.
36 Plymouth Coupe
318 w/360 heads
518 trans
8 3/4 rear
Ga. Tech BCE'78
Re: Tie rod end taper [Re: 36PLYM] #755213
07/23/10 07:08 PM
07/23/10 07:08 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Somewhere I have stashed an old TRW chassis component spec book. But I wouldn't bet on me being able to find it anytime soon. As for the nut bottoming out, a washer works well as a spacer.
Re: Tie rod end taper [Re: 36PLYM] #755214
07/23/10 08:10 PM
07/23/10 08:10 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Check with mr2perforemance member on moparts, he makes bushings, might fit your needs. Page 70 on the user list
