70 BBody 1/4 mile time? #755176
07/22/10 01:01 PM
07/22/10 01:01 PM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
I have a 440 bored .030 over with a Lunati 60302 cam andpossibly a 3.73 gear posi. Holley 750 dual line vaccum secondary carb. Stock torque converter and 727 Tranny. What kind of time should I expect to get in the 1/4?
Re: 70 BBody 1/4 mile time? [Re: roy2345] #755177
07/22/10 01:55 PM
07/22/10 01:55 PM
MT
cudabruce Offline
cudabruce  Offline
MT
13's, but thats just a guess. Ive seen guys with nothing special that knew how to dial in a car and drive it run mid 11's. On the other side Ive seen some straight out drag car set ups run 14's
Re: 70 BBody 1/4 mile time? [Re: roy2345] #755178
07/23/10 12:54 PM
07/23/10 12:54 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Guesstimating about mid 14's to 14 flat. To hit
13's, you need 3.91,s or better or with the 3.73's
a little more stall in the converter and sort out the weight transfer in the suspension.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: 70 BBody 1/4 mile time? [Re: roy2345] #755179
07/23/10 12:57 PM
07/23/10 12:57 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Stock intake and exhaust manifolds?? 2 1/4" exhaust with stock mufflers??
Cam is vertually stock (Ok a smiggin above) so I'm in the mid to low 14 camp
Re: 70 BBody 1/4 mile time? [Re: Dodgem] #755180
07/23/10 01:15 PM
07/23/10 01:15 PM
My :
If your compression ratio is at least 9:1, your carb is opening all the way, your ignition advance is halfway close to right, and you know how to drive, I'd say high 13's. A better convertor would be worth several tenths.
Re: 70 BBody 1/4 mile time? [Re: roy2345] #755181
07/23/10 05:45 PM
07/23/10 05:45 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
depends on a lot of things. Is the carb tuned well? Have you drag raced before? slicks? Take a box full of jets and your timing light to the track. I suggest starting with 78-84 w/ 31 squirters and a 6.5 PV. Set for best vacuum. Start your timing at 38* (no vacuum advance) @ 2400rpm. Bring the car up on the converter slighty then waffle it when the last yellow lights. Shift around 5400. If you have headers try 5600. Good luck and have fun. I ran 12.90's w/ less cam but a little more gear (3.91) and a little more stall (2600) and slicks. I'd think you should see mid 13's once you get it all sorted out. Don't get upset if you pull a high 14 out 1st few runs. Have fun.
Coming soon!!!!
Re: 70 BBody 1/4 mile time? [Re: roy2345] #755182
07/23/10 06:08 PM
07/23/10 06:08 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
need more info on motor, what comp,valve size,head work and type,cam lift,rocker ratio/type,hp manifolds or headers what tubes,intake,mp elec dizzy ect?, manual valve body auto?and s/s springs and what size/tire combo. with that info i could guess real close
MOPAR OR NO CAR
Re: 70 BBody 1/4 mile time? [Re: roy2345] #755183
07/23/10 07:17 PM
07/23/10 07:17 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Too many variables to tell...need more details and even then it will be guesswork.
Re: 70 BBody 1/4 mile time? [Re: Mr.Yuck] #755184
07/23/10 09:04 PM
07/23/10 09:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I ran 12.90's w/ less cam but...
Really? The 60302 is pretty small, like 262/268 advertised, 220/226 @ 0.50".
Re: 70 BBody 1/4 mile time? [Re: Mr.Yuck] #755185
07/24/10 01:33 AM
07/24/10 01:33 AM
Desert Tracker
Desert Tracker
Re: 70 BBody 1/4 mile time? [Re: BSB67] #755186
07/24/10 10:17 AM
07/24/10 10:17 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yes I ran 12.90's in a 67 coronet w/ a 70 440 (maybe 9:1) stock 906 heads, headers, RPM intake, 750 DP and a summit 224/234-465/488 cam. I had a 175k converter and 3.91's.
Re: 70 BBody 1/4 mile time? [Re: Mr.Yuck] #755187
07/24/10 07:14 PM
07/24/10 07:14 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Well done!
But your cam is a little bigger, not smaller.
Re: 70 BBody 1/4 mile time? [Re: BSB67] #755188
07/24/10 08:15 PM
07/24/10 08:15 PM
south carolina U.S.
DOUGG Offline
DOUGG  Offline
south carolina U.S.
i have the same cam/carb in a 383 in my 65 satellite with 3.55 gears and ran 13.70's .3500 lb. car and running extremely lean in high rpm;s due to 5/16 pick-up in fuel tank. yours should do pretty well once it's dialed in. ENJOY!!!
Re: 70 BBody 1/4 mile time? [Re: Mr.Yuck] #755189
07/26/10 03:59 PM
07/26/10 03:59 PM
Desert Tracker
Desert Tracker
Great combo! But the 67' weighs 200-400 lbs less
than the average 440 equipped 70' B-body. 70 B-bodies weigh between 3800-4100 lbs depending how
it's optioned.
Re: 70 BBody 1/4 mile time? [Re: HYPER8oSoNic] #755190
07/27/10 10:36 AM
07/27/10 10:36 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
it's optioned.
really? my 67 weighed almost 3900lbs w/ me a 1/2 tank of gas.
Re: 70 BBody 1/4 mile time? [Re: Mr.Yuck] #755191
07/27/10 09:32 PM
07/27/10 09:32 PM
Desert Tracker
Desert Tracker
it's optioned.
How much do YOU WEIGH? And my quotes are WITHOUT
the driver from a "stripper" version to the "fully
dressed" version.
Re: 70 BBody 1/4 mile time? [Re: HYPER8oSoNic] #755192
07/27/10 09:39 PM
07/27/10 09:39 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
What?
My 69 b body which is the same car as a 70 weighs 3620 w/ better than a half tank. 440 would add only a few pounds over my 383. I have maybe 75 pounds AT THE MOST in aluminum stuff weight savings.
I also have a full spare and a jack at the 3620 weight. Power steering would add I think 46 pounds based on what others have figured on here. MA article said 90 vs. 12 so...
Re: 70 BBody 1/4 mile time? [Re: HYPER8oSoNic] #755193
07/28/10 09:45 AM
07/28/10 09:45 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
it's optioned.
dressed" version.
I weigh around 185. The car is was all stock steel, no fiberglass. I did not have the spare and jack in the car. I weighed it at the track, this was an "as raced" weight. I'm guessing after 4-6 passes it'd lose a few lbs of fuel weight. The car did have PS and A/C. The A/C box was in the car but the junk under the hood was removed.
Re: 70 BBody 1/4 mile time? [Re: Mr.Yuck] #755194
07/28/10 01:57 PM
07/28/10 01:57 PM
SomeCarGuy Offline
SomeCarGuy  Offline
The 66-67 is pretty much the same car underneath the cosmetics, so I don't see where they would weight that much different than the later years.
Re: 70 BBody 1/4 mile time? [Re: SomeCarGuy] #755195
07/29/10 09:09 AM
07/29/10 09:09 AM
GA
roy2345 Offline OP
roy2345  Offline OP
GA
Thanks for the knowledge guys! Yall always come through for me! I appreciate you all!
