Re: 70 BBody 1/4 mile time?
[Re: Dodgem]
#755180
07/23/10 01:15 PM
07/23/10 01:15 PM
My : If your compression ratio is at least 9:1, your carb is opening all the way, your ignition advance is halfway close to right, and you know how to drive, I'd say high 13's. A better convertor would be worth several tenths.
[Re: roy2345]
#755182
07/23/10 06:08 PM
07/23/10 06:08 PM
Posts: 2,315 MOPAR HEADQUARTERS IN ALDEN NY
hemigod426
need more info on motor, what comp,valve size,head work and type,cam lift,rocker ratio/type,hp manifolds or headers what tubes,intake,mp elec dizzy ect?, manual valve body auto?and s/s springs and what size/tire combo. with that info i could guess real close
MOPAR OR NO CAR
[Re: Mr.Yuck]
#755184
07/23/10 09:04 PM
07/23/10 09:04 PM
Posts: 4,316 Prospect, PA
BSB67
Prospect, PA
I ran 12.90's w/ less cam but...
Really? The 60302 is pretty small, like 262/268 advertised, 220/226 @ 0.50".
[Re: BSB67]
#755186
07/24/10 10:17 AM
07/24/10 10:17 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
yes I ran 12.90's in a 67 coronet w/ a 70 440 (maybe 9:1) stock 906 heads, headers, RPM intake, 750 DP and a summit 224/234-465/488 cam. I had a 175k converter and 3.91's.
[Re: Mr.Yuck]
#755187
07/24/10 07:14 PM
07/24/10 07:14 PM
BSB67
Prospect, PA
Well done!
But your cam is a little bigger, not smaller.
[Re: HYPER8oSoNic]
#755190
07/27/10 10:36 AM
07/27/10 10:36 AM
Mr.Yuck
Brookeville, Md
Great combo! But the 67' weighs 200-400 lbs less than the average 440 equipped 70' B-body. 70 B-bodies weigh between 3800-4100 lbs depending how it's optioned.
really? my 67 weighed almost 3900lbs w/ me a 1/2 tank of gas.
[Re: HYPER8oSoNic]
#755193
07/28/10 09:45 AM
07/28/10 09:45 AM
Mr.Yuck
Brookeville, Md
How much do YOU WEIGH? And my quotes are WITHOUT the driver from a "stripper" version to the "fully dressed" version.
I weigh around 185. The car is was all stock steel, no fiberglass. I did not have the spare and jack in the car. I weighed it at the track, this was an "as raced" weight. I'm guessing after 4-6 passes it'd lose a few lbs of fuel weight. The car did have PS and A/C. The A/C box was in the car but the junk under the hood was removed.
