Trunk Harness Outer Wrap
#754675
07/21/10 07:47 PM
07/21/10 07:47 PM
Posts: 1,169 Richmond, VA
rayztoy
Richmond, VA
Hello Guys, What are you guys using to wrap the trunk harness wiring these days thats close to original? Thanks. Ray
Re: Trunk Harness Outer Wrap
[Re: rayztoy]
#754680
07/22/10 10:00 AM
07/22/10 10:00 AM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
Here is a trick I used. The wrap was in excellent shape between the wheel well and the front connector. I slid it down towards the rear of the harness to replace the disintrated section and used the non stick wrap for the section you don't see.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: rayztoy]
#754681
07/22/10 12:58 PM
07/22/10 12:58 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
Thank you Snoopy. Do you know if M&H wraps the harnesses themselves or sends them out for wrapping?
Ray
I don't know if they do it in house or send it out. I seem to remember hearing that they send it out. Give Tom (M&H) a call and see if he can restore your harness or point you in the right direction? (562)926-9562
[Re: Snoopy]
#754682
07/22/10 02:11 PM
07/22/10 02:11 PM
Posts: 5,268 NY
70440+6bbl
NY
Didn't Moparts member BeepBeep (Joe A) offer that service using the correct paper material?
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: 70440+6bbl]
#754684
07/26/10 05:44 PM
07/26/10 05:44 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Yes, but he did state it might not be cost effective if the harness itself was in a degraded condition so I'm assumed it was'nt a cheap alternative to just buying the new harness...
[Re: screamindriver]
#754685
07/26/10 06:06 PM
07/26/10 06:06 PM
rayztoy
Richmond, VA
Colin, Do you know of a wrap that is simiar to the original? Does the repro YO harness have the correct wrap? Ray
[Re: RoadRunner]
#754686
07/27/10 09:27 AM
07/27/10 09:27 AM
Posts: 4,764 near Port Huron, MI
Paul
near Port Huron, MI
I've done the same as well, it's a cheap and easy way to make your old harness look new again.
[Re: Paul]
#754687
07/27/10 02:10 PM
07/27/10 02:10 PM
rayztoy
Richmond, VA
What if you don't have any wrap under the carpet?
[Re: rayztoy]
#754688
07/28/10 08:18 PM
07/28/10 08:18 PM
screamindriver
Harrisburg, Pa.
Hi Ray...The M&H [Y-1] does have the paper braid wrap around the harness{And ECS carries the harness tags}...That would be the easy way out for the most convincing end product...There really is'nt anything available {aftermarket} that matches the correct wrap for your harness....So other choices are a good original or slide the wrap as suggested....Heck, I've damaged some paper braid wrap just trying to clean it so be careful if you go that route...
