Trunk Harness Outer Wrap #754675
07/21/10 07:47 PM
07/21/10 07:47 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Hello Guys,
What are you guys using to wrap the trunk harness wiring these days thats close to original? Thanks.
Ray
Re: Trunk Harness Outer Wrap [Re: rayztoy] #754676
07/21/10 09:27 PM
07/21/10 09:27 PM
N.E. OHIO
P
polara426 Offline
polara426  Offline
P
N.E. OHIO
What year car picture looks like friction tape should work ealy cars had clothe wrap that evan,s wiring harness restored for me great job
Re: Trunk Harness Outer Wrap [Re: polara426] #754677
07/21/10 09:35 PM
07/21/10 09:35 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
A 1970 Cuda. Here's a closeup of the outer wrapper.
Re: Trunk Harness Outer Wrap [Re: rayztoy] #754678
07/21/10 11:06 PM
07/21/10 11:06 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Your only option is to buy a new one from Year One.
Re: Trunk Harness Outer Wrap [Re: Snoopy] #754679
07/22/10 08:21 AM
07/22/10 08:21 AM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Thank you Snoopy. Do you know if M&H wraps the harnesses themselves or sends them out for wrapping?
Ray
Re: Trunk Harness Outer Wrap [Re: rayztoy] #754680
07/22/10 10:00 AM
07/22/10 10:00 AM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
Here is a trick I used. The wrap was in excellent shape between the wheel well and the front connector. I slid it down towards the rear of the harness to replace the disintrated section and used the non stick wrap for the section you don't see.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Trunk Harness Outer Wrap [Re: rayztoy] #754681
07/22/10 12:58 PM
07/22/10 12:58 PM
Snoopy Offline
Snoopy  Offline
Ray
I don't know if they do it in house or send it out. I seem to remember hearing that they send it out.
Give Tom (M&H) a call and see if he can restore your harness or point you in the right direction?
(562)926-9562
Re: Trunk Harness Outer Wrap [Re: Snoopy] #754682
07/22/10 02:11 PM
07/22/10 02:11 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Didn't Moparts member BeepBeep (Joe A) offer that service using the correct paper material?
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: Trunk Harness Outer Wrap [Re: 70440+6bbl] #754683
07/25/10 05:19 PM
07/25/10 05:19 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Re: Trunk Harness Outer Wrap [Re: 70440+6bbl] #754684
07/26/10 05:44 PM
07/26/10 05:44 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Yes, but he did state it might not be cost effective if the harness itself was in a degraded condition so I'm assumed it was'nt a cheap alternative to just buying the new harness...
Re: Trunk Harness Outer Wrap [Re: screamindriver] #754685
07/26/10 06:06 PM
07/26/10 06:06 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
Colin,
Do you know of a wrap that is simiar to the original? Does the repro YO harness have the correct wrap?
Ray
Re: Trunk Harness Outer Wrap [Re: RoadRunner] #754686
07/27/10 09:27 AM
07/27/10 09:27 AM
near Port Huron, MI
Paul Offline
Paul  Offline
near Port Huron, MI
I've done the same as well, it's a cheap and easy way to make your old harness look new again.
Re: Trunk Harness Outer Wrap [Re: Paul] #754687
07/27/10 02:10 PM
07/27/10 02:10 PM
Richmond, VA
rayztoy Offline OP
rayztoy  Offline OP
Richmond, VA
What if you don't have any wrap under the carpet?
Re: Trunk Harness Outer Wrap [Re: rayztoy] #754688
07/28/10 08:18 PM
07/28/10 08:18 PM
Harrisburg, Pa.
Harrisburg, Pa.
Colin,
Ray
Hi Ray...The M&H [Y-1] does have the paper braid wrap around the harness{And ECS carries the harness tags}...That would be the easy way out for the most convincing end product...There really is'nt anything available {aftermarket} that matches the correct wrap for your harness....So other choices are a good original or slide the wrap as suggested....Heck, I've damaged some paper braid wrap just trying to clean it so be careful if you go that route...
