Page 4 of 4 1 2 3 4
Re: Kudo's to Vic..AKA S/ST 3040 [Re: Dunnuck Racing] #752448
07/30/10 11:47 AM
07/30/10 11:47 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
When do you plan on hitting the track again????
September 17th @ Norwalk. Just Kidding.
I'm not sure but, I'll probably take it back to Martin.
They have 330', 660' 1000' incrementals to tune off
of and better surface than you know who.
I really need to work on the 60'
Re: Kudo's to Vic..AKA S/ST 3040 [Re: S/ST 3040] #752449
07/30/10 11:52 AM
07/30/10 11:52 AM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
Let me know when,I have my crap-wagon's front end tore down,the rear suspension WILL happen this winter.
Re: Kudo's to Vic..AKA S/ST 3040 [Re: Dunnuck Racing] #752450
07/30/10 11:57 AM
07/30/10 11:57 AM
S/ST 3040 Offline
S/ST 3040  Offline
Re: Kudo's to Vic..AKA S/ST 3040 [Re: S/ST 3040] #752451
08/02/10 12:43 AM
08/02/10 12:43 AM
Lexington South Carolina
johnnyp Offline
johnnyp  Offline
Which way would you have rather went on the headers to keep the 20 hp you don't have.
Re: Kudo's to Vic..AKA S/ST 3040 [Re: johnnyp] #752452
08/02/10 09:00 AM
08/02/10 09:00 AM
S/ST 3040 Offline
S/ST 3040  Offline
I was just kidding Jeremy. He got me a good deal on these.
I'd rather have 1 3/4" primaries or 1 3/4' x 15 1/2" stepped
up to 1 7/8" and another 1 1/2" in collector length.
There might be 15-20 HP and 15 ft/lbs there. $tahl make$
them but, these will have to do. I need a dyno.
Re: Kudo's to Vic..AKA S/ST 3040 [Re: S/ST 3040] #752453
08/02/10 02:46 PM
08/02/10 02:46 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Hey Vic...
Check this out, dont know how much but....
Yummy!!!
MW part # RT-39002
Re: Kudo's to Vic..AKA S/ST 3040 [Re: theclutcher] #752454
08/02/10 04:46 PM
08/02/10 04:46 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Hey Vic, please excuse my experience on flow bench stuff but..... if you can flow a head and intake ,why cant you flow a head and header Oh one more thing, you are running a solid roller yes? and I did not... ... ask for the specs
Re: Kudo's to Vic..AKA S/ST 3040 [Re: earthmover] #752455
08/02/10 05:13 PM
08/02/10 05:13 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Hay vic what kind of hp you think you got with this build? If you don't mind me asking .keep this small block stuff going
Re: Kudo's to Vic..AKA S/ST 3040 [Re: emarine01] #752456
08/02/10 05:21 PM
08/02/10 05:21 PM
S/ST 3040 Offline
S/ST 3040  Offline
Yes you can flow almost anything.......carburetors, plus intake and heads, exhaust ports with
headers bolted to them, blowers, etc. The problem is......there is way more going on inside the
intake and exhaust tracts, that static airflow don't, won't and can't tell you.
It is a solid roller. You were correct in your assumtion, that is the extent of my disclosure.
Re: Kudo's to Vic..AKA S/ST 3040 [Re: S/ST 3040] #752457
08/02/10 05:34 PM
08/02/10 05:34 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Well I knew better on the cam thing < this time> Even if Brett spills the beans I promise I wont read it Thankx for the head pic
Re: Kudo's to Vic..AKA S/ST 3040 [Re: emarine01] #752458
08/02/10 05:39 PM
08/02/10 05:39 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
I saw his cam box and card........
Its a hydralic cam, 230@50, about 500 lift
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Kudo's to Vic..AKA S/ST 3040 [Re: earthmover] #752459
08/02/10 05:46 PM
08/02/10 05:46 PM
S/ST 3040 Offline
S/ST 3040  Offline
In it's current state of tune.......445 HP
I know that's nothing to write home about but, it's the
same "dyno" I use to judge everybody else.
Re: Kudo's to Vic..AKA S/ST 3040 [Re: S/ST 3040] #752460
08/03/10 03:03 PM
08/03/10 03:03 PM
IL
knyech1 Offline
knyech1  Offline
IL
Oh shoot I knew you were messin with me! And though I did get you a steal of a deal on those headers, I still owe you for all the things you done for me!!
What would you need to do to make these headers more effective? Maybe...I hate to say it...more cubic inches? I am guessing either that or more RPM.
knyech1- '71 Sassy Grass Demon 340/904. Pump gas, 1.61 60ft, 7.439 1/8 @ 95mph, 11.824 1/4 @ 111mph "Not too bad for a pump gas 340, full of used parts and hillbilly ported stock heads." - V.B. '03 2500 5.9L HO 6-spd on 35's. 395hp/755ft-lb at tires.
Re: Kudo's to Vic..AKA S/ST 3040 [Re: knyech1] #752461
08/03/10 03:43 PM
08/03/10 03:43 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I got a set o them 974s for sale for $50
Disclaimer... they may need some work to run 9s
Page 4 of 4 1 2 3 4
