Re: Kudo's to Vic..AKA S/ST 3040
[Re: Dunnuck Racing]
#752448
07/30/10 11:47 AM
07/30/10 11:47 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
When do you plan on hitting the track again????
September 17th @ Norwalk. Just Kidding.
I'm not sure but, I'll probably take it back to Martin. They have 330', 660' 1000' incrementals to tune off of and better surface than you know who.
I really need to work on the 60'
[Re: johnnyp]
#752452
08/02/10 09:00 AM
08/02/10 09:00 AM
S/ST 3040
Which way would you have rather went on the headers to keep the 20 hp you don't have.
I was just kidding Jeremy. He got me a good deal on these.
I'd rather have 1 3/4" primaries or 1 3/4' x 15 1/2" stepped up to 1 7/8" and another 1 1/2" in collector length.
There might be 15-20 HP and 15 ft/lbs there. $tahl make$ them but, these will have to do. I need a dyno.
[Re: emarine01]
#752456
08/02/10 05:21 PM
08/02/10 05:21 PM
S/ST 3040
Hey Vic, please excuse my experience on flow bench stuff but..... if you can flow a head and intake ,why cant you flow a head and header Oh one more thing, you are running a solid roller yes? and I did not... ... ask for the specs
Yes you can flow almost anything.......carburetors, plus intake and heads, exhaust ports with headers bolted to them, blowers, etc. The problem is......there is way more going on inside the intake and exhaust tracts, that static airflow don't, won't and can't tell you.
It is a solid roller. You were correct in your assumtion, that is the extent of my disclosure.
[Re: emarine01]
#752458
08/02/10 05:39 PM
08/02/10 05:39 PM
Posts: 11,718 Portage,michigan
B3422W5
Portage,michigan
Well I knew better on the cam thing < this time> Even if Brett spills the beans I promise I wont read it Thankx for the head pic
I saw his cam box and card........
Its a hydralic cam, 230@50, about 500 lift
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: earthmover]
#752459
08/02/10 05:46 PM
08/02/10 05:46 PM
S/ST 3040
Hay vic what kind of hp you think you got with this build? If you don't mind me asking .keep this small block stuff going
In it's current state of tune.......445 HP
I know that's nothing to write home about but, it's the same "dyno" I use to judge everybody else.
