Re: need transbrake help please
[Re: moparjimbo60]
#751935
07/18/10 09:56 PM
07/18/10 09:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
At what rpm did you set the brake at... seems that some of the T/A brakes you need to be about 1500 rpm's or better then you can go to the set rpm... otherwise you dont have enough line pressure
[Re: moparjimbo60]
#751937
07/18/10 11:26 PM
07/18/10 11:26 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
what stall converter ? are you over it's maximum? tie line lock and brake to work together
home of the Sox and Martin Hemi Duster
[Re: MR_P_BODY]
#751939
07/18/10 11:29 PM
07/18/10 11:29 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
[Re: moparjimbo60]
#751943
07/19/10 07:38 AM
07/19/10 07:38 AM
MR_P_BODY
yes i have heard that was rolling in about 2500 rpm then setting the brake. i have a 5500 stall converter so im not running up on it .
Have you checked the line pressure... very important on a T-brake
[Re: moparjimbo60]
#751945
07/19/10 08:53 AM
07/19/10 08:53 AM
MR_P_BODY
no havent checked that but the last time i used the brake it was fine. just have not used it in about a year . is it possible the seleniod is bad or weak. i will check line pressure.
I had a problem with a older T/A brake that had a machining issue... both me and my tranny guy had the same issue... he called them and they sent out 2 parts for both of our units... a wall in the brake was flexing back and forth with the pressure and finally cracked and it would bleed off pressure allowing it to creap and finally wouldnt hold at all.... since then its been great(about 8 years now)
