need transbrake help please #751933
07/18/10 09:47 PM
07/18/10 09:47 PM
Georgia
moparjimbo60 Offline OP
Georgia
tryed to use my t- brake in footbrake, tryed adjusting the rpm to cut a better light, tryed it at 3400 and the car pushed thru the lights, went around again at 3800 to 4000 and it still pushed thru , what the heck is giong on. its a turbo action brake, is there a fix or just trash it for a real brake......
Re: need transbrake help please [Re: moparjimbo60] #751934
07/18/10 09:51 PM
07/18/10 09:51 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Well using a trans brake in foot brake is generally against the rules!!
Re: need transbrake help please [Re: moparjimbo60] #751935
07/18/10 09:56 PM
07/18/10 09:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
At what rpm did you set the brake at... seems that some
of the T/A brakes you need to be about 1500 rpm's or
better then you can go to the set rpm... otherwise you
dont have enough line pressure
Re: need transbrake help please [Re: Dodgem] #751936
07/18/10 09:57 PM
07/18/10 09:57 PM
Georgia
Georgia
not the tracks we run in ga. and ala. just cant run a delay box.
Re: need transbrake help please [Re: moparjimbo60] #751937
07/18/10 11:26 PM
07/18/10 11:26 PM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
what stall converter ? are you over it's maximum?
tie line lock and brake to work together
home of the
Sox and Martin Hemi Duster
Re: need transbrake help please [Re: HEMIFRED] #751938
07/18/10 11:28 PM
07/18/10 11:28 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
What brand of brake?
Re: need transbrake help please [Re: MR_P_BODY] #751939
07/18/10 11:29 PM
07/18/10 11:29 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: need transbrake help please [Re: WILD BILL] #751940
07/19/10 12:13 AM
07/19/10 12:13 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
my brake does the same thing and its a tranzact
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: need transbrake help please [Re: Ian] #751941
07/19/10 01:04 AM
07/19/10 01:04 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
were you in 1st or D? i had a TA brake, it worked very well, cut real good lights with it & it could be set at idle, if you weren't in 1st you might have a line pressure problem. with everything turned off can you hear the solenoid click when you activate the button?
Re: need transbrake help please [Re: MR_P_BODY] #751942
07/19/10 07:33 AM
07/19/10 07:33 AM
Georgia
Georgia
yes i have heard that was rolling in about 2500 rpm then setting the brake. i have a 5500 stall converter so im not running up on it .
Re: need transbrake help please [Re: moparjimbo60] #751943
07/19/10 07:38 AM
07/19/10 07:38 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you checked the line pressure... very important
on a T-brake
Re: need transbrake help please [Re: MR_P_BODY] #751944
07/19/10 08:33 AM
07/19/10 08:33 AM
Georgia
Georgia
no havent checked that but the last time i used the brake it was fine. just have not used it in about a year . is it possible the seleniod is bad or weak. i will check line pressure.
Re: need transbrake help please [Re: moparjimbo60] #751945
07/19/10 08:53 AM
07/19/10 08:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I had a problem with a older T/A brake that had a
machining issue... both me and my tranny guy had the
same issue... he called them and they sent out 2 parts
for both of our units... a wall in the brake was flexing
back and forth with the pressure and finally cracked
and it would bleed off pressure allowing it to creap
and finally wouldnt hold at all.... since then its
been great(about 8 years now)
Re: need transbrake help please [Re: MR_P_BODY] #751946
07/19/10 09:07 PM
07/19/10 09:07 PM
Georgia
Georgia
thanks i will give them a call tommorow
