Reverse cooling a big block; who sells parts/kits... #741388
07/06/10 02:54 AM
07/06/10 02:54 AM
WA 98043
thecarfarmer Offline OP
WA 98043
...besides Indy?
I've seen their kit; wanted to know what other options there are out there.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Reverse cooling a big block; who sells parts/kits... [Re: thecarfarmer] #741389
07/06/10 04:48 AM
07/06/10 04:48 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
mezzaire sell the pump. it requires no kit to install but if you want to run accessories you need to be good at fabricating new mounting points & brackets.
Re: Reverse cooling a big block; who sells parts/kits... [Re: rebel] #741390
07/06/10 08:00 AM
07/06/10 08:00 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use the Indy,quite simple and effective,Donnies 605"Hemi never see 195* and is 175* by the time he gets back to the pits.
Re: Reverse cooling a big block; who sells parts/kits... [Re: thecarfarmer] #741391
07/06/10 09:01 AM
07/06/10 09:01 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Mezzaire sells plates that accept fittings if you want to run a remote mounted pump , also have seen a manifold of some sort also for use with a remote mount pump.
Re: Reverse cooling a big block; who sells parts/kits... [Re: JohnRR] #741392
07/06/10 10:05 AM
07/06/10 10:05 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I believe AndyF sells block fittings as well. I have used the Meziere ones but now use the Mesiere pump. The Indy set up it simply a "manifold" that uses a SBC pump. I believe it is less costly to just use the Meziere pump.
Re: Reverse cooling a big block; who sells parts/kits... [Re: thecarfarmer] #741393
07/06/10 11:03 AM
07/06/10 11:03 AM
AndyF Offline
AndyF  Offline
There are several options. I sell water manifolds that bolt onto the block to use with a remote pump. You can hook up the lines to reverse cool if you want or you can run the lines in the normal way.
I also have a Meziere reverse flow water pump for sale. It was in the for sale section last month but I haven't gotten the ad posted yet this month.
Re: Reverse cooling a big block; who sells parts/kits... [Re: AndyF] #741394
07/06/10 11:06 AM
07/06/10 11:06 AM
AndyF Offline
AndyF  Offline
This is what the Meziere pump looks like. It is a simple bolt on pump that pushes the water flow in reverse. You need to hook up the two outlets to your radiator with a Y fitting or install two inlets in the top tank.
Re: Reverse cooling a big block; who sells parts/kits... [Re: AndyF] #741395
07/13/10 10:37 PM
07/13/10 10:37 PM
Duncan B.C.
440truc Offline
440truc  Offline
Duncan B.C.
CSR makes a reverse flow pump, does anyone know anything about them? I am looking into getting one. CSR is out of stock right now but there is some on ebay for $499 with fittings!
Re: Reverse cooling a big block; who sells parts/kits. [Re: 440truc] #741396
07/14/10 12:02 PM
07/14/10 12:02 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Are they really worth any hp?
Re: Reverse cooling a big block; who sells parts/kits... [Re: 440truc] #741397
07/14/10 12:39 PM
07/14/10 12:39 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have the csr pump. i like it. My car runs 160-175.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Reverse cooling a big block; who sells parts/kits... [Re: bigtimeauto] #741398
07/14/10 03:21 PM
07/14/10 03:21 PM
Duncan B.C.
440truc Offline
440truc  Offline
Duncan B.C.
Any idea how it would be on the street?
81 Dodge 440 street truck 10.83 @120mph
Re: Reverse cooling a big block; who sells parts/kits... [Re: AndyF] #741399
07/14/10 04:27 PM
07/14/10 04:27 PM
ky hills
thehemikid Offline
thehemikid  Offline
ky hills
...Also, doesn't Mesiere have a pump that has a 55 gph rating.
Re: Reverse cooling a big block; who sells parts/kits... [Re: thehemikid] #741400
07/14/10 05:55 PM
07/14/10 05:55 PM
yes they have them. i just bought one in black.
Re: Reverse cooling a big block; who sells parts/kits... #741401
07/14/10 10:32 PM
07/14/10 10:32 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I`ve got the Indy and my557 stays under 200 .
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Reverse cooling a big block; who sells parts/kits. [Re: Tig] #741402
07/15/10 01:45 AM
07/15/10 01:45 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
well the story as i was told goes like this... if the heads are first to get the cooled water then you can increase timing & fuel so with less chance of detonation you get to make more power. does it???? not sure, i had cooling issues before i bought my mezzarie reverse flow & i added an alloy radiator since it needed -12 fittings for the water return. i'm definately running faster than i used to but couldn't say 100% it was all related to the pump deal.
Re: Reverse cooling a big block; who sells parts/kits. [Re: rebel] #741403
07/15/10 11:20 AM
07/15/10 11:20 AM
My reverse flow waterpump started leaking and I got a replacement from Harbor Freight that with a little modification seems to be working as well as the old pump. Just a little noisy
http://www.harborfreight.com/catalogsearch/result/?category=&q=waterpump+12+volt
Just thought I would throw that out there in case you get in a bind. I tried a boat supplier but they were out.
