Reverse cooling a big block; who sells parts/kits...
#741388
07/06/10 02:54 AM
07/06/10 02:54 AM
Posts: 871 WA 98043
thecarfarmer
WA 98043
...besides Indy?
I've seen their kit; wanted to know what other options there are out there.
-Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Reverse cooling a big block; who sells parts/kits...
[Re: JohnRR]
#741392
07/06/10 10:05 AM
07/06/10 10:05 AM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
I believe AndyF sells block fittings as well. I have used the Meziere ones but now use the Mesiere pump. The Indy set up it simply a "manifold" that uses a SBC pump. I believe it is less costly to just use the Meziere pump.
[Re: 440truc]
#741396
07/14/10 12:02 PM
07/14/10 12:02 PM
Posts: 2,937 A shed in England
Tig
A shed in England
Are they really worth any hp? ![](/ubbthreads/images/graemlins/shruggy.gif)
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: bigtimeauto]
#741398
07/14/10 03:21 PM
07/14/10 03:21 PM
Posts: 10 Duncan B.C.
440truc
Duncan B.C.
Any idea how it would be on the street?
81 Dodge 440 street truck 10.83 @120mph
[Re: thehemikid]
#741400
07/14/10 05:55 PM
07/14/10 05:55 PM
...Also, doesn't Mesiere have a pump that has a 55 gph rating.
yes they have them. i just bought one in black.
#741401
07/14/10 10:32 PM
07/14/10 10:32 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
I`ve got the Indy and my557 stays under 200 .
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: Tig]
#741402
07/15/10 01:45 AM
07/15/10 01:45 AM
Posts: 4,647 aotearoa
rebel
aotearoa
well the story as i was told goes like this... if the heads are first to get the cooled water then you can increase timing & fuel so with less chance of detonation you get to make more power. does it???? not sure, i had cooling issues before i bought my mezzarie reverse flow & i added an alloy radiator since it needed -12 fittings for the water return. i'm definately running faster than i used to but couldn't say 100% it was all related to the pump deal.
[Re: rebel]
#741403
07/15/10 11:20 AM
07/15/10 11:20 AM
My reverse flow waterpump started leaking and I got a replacement from Harbor Freight that with a little modification seems to be working as well as the old pump. Just a little noisy http://www.harborfreight.com/catalogsearch/result/?category=&q=waterpump+12+volt Just thought I would throw that out there in case you get in a bind. I tried a boat supplier but they were out. ![](http://farm4.static.flickr.com/3039/2682307335_4f1ffb100b.jpg)
