a few dull tubes on my headers #723115
06/13/10 04:58 PM
06/13/10 04:58 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
A few weeks ago I raced my Savoy for a few shakedown runs without the mufflers and I noticed a few of my tubes are now slightly dull.This means I have a lean issue causing the excessive heat on a few tubes no?
I never had this problem with a few hundred miles on the street with full exhaust.
Gus
64 Plymouth Savoy
Dana 60
Re: a few dull tubes on my headers [Re: fourgearsavoy] #723116
06/13/10 07:00 PM
06/13/10 07:00 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Could also be too rich, unburn fuel burning inside tubes.
Re: a few dull tubes on my headers [Re: nss guy] #723117
06/13/10 07:09 PM
06/13/10 07:09 PM
Rittman Ohio
Rittman Ohio
Well I pulled the plugs from the pipes in question and they are white/gray but no aluminum yet I am going up a few sizes on the primaries as the front tubes are the ones getting dull #1 and #2 plugs look like they are more lean than the rest.
Gus
64 Plymouth Savoy
Dana 60
Re: a few dull tubes on my headers [Re: fourgearsavoy] #723118
06/13/10 07:22 PM
06/13/10 07:22 PM
Casa Grande,Arizona
DennisJ Offline
super street
DennisJ  Offline
super street
Casa Grande,Arizona
What did she run?
Dennis Jokela
I started out with nothing,and I still have most of it.
Re: a few dull tubes on my headers [Re: DennisJ] #723119
06/13/10 07:39 PM
06/13/10 07:39 PM
Rittman Ohio
Rittman Ohio
I just ran a 7.34 with very little traction with a 1.7 60' and my car usually done a 1.5 with a 9" tire.I think my new engine might be a little too much for a 9" tire.The ET Street radial went up in smoke instantly when I tried those.Then I put on a brand new pair of 9-28 ET slicks and it brought my 60 from 2.3 to 1.7. I may need a minitub and a 10.5 tire.
Gus
64 Plymouth Savoy
Dana 60
Re: a few dull tubes on my headers [Re: fourgearsavoy] #723120
06/13/10 07:48 PM
06/13/10 07:48 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Gus
You can try fattening that corner of the carb or you
might need to balance the intake runners for more flow
on those cylinders... if you had egt's in all of
the tubes you could use them to set the intake balance
Re: a few dull tubes on my headers [Re: fourgearsavoy] #723121
06/13/10 11:00 PM
06/13/10 11:00 PM
which intake, carbs and jetting are you using now Gus?
Re: a few dull tubes on my headers [Re: Cab_Burge] #723122
06/13/10 11:08 PM
06/13/10 11:08 PM
Rittman Ohio
Rittman Ohio
Well Cab I have an Edelbrock Performer RPM,Pro-Max 1050 body 4150 style carb,82's and 4.5 PV primary and 90's and blocked PV in the rear.
Gus
64 Plymouth Savoy
Dana 60
Re: a few dull tubes on my headers [Re: fourgearsavoy] #723123
06/13/10 11:11 PM
06/13/10 11:11 PM
I was thinking that you may have had a OEM crossram with two Carter or Eddy carbs. Good luck getting the distribution correct
Re: a few dull tubes on my headers [Re: Cab_Burge] #723124
06/14/10 08:54 AM
06/14/10 08:54 AM
Rittman Ohio
Rittman Ohio
Yeah maybe someday when I become rich and shameless until then I will just have to jet up a few clicks and read my plugs like always.
Thanks Cab
Gus
64 Plymouth Savoy
Dana 60
