a few dull tubes on my headers
#723115
06/13/10 04:58 PM
06/13/10 04:58 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
A few weeks ago I raced my Savoy for a few shakedown runs without the mufflers and I noticed a few of my tubes are now slightly dull.This means I have a lean issue causing the excessive heat on a few tubes no? I never had this problem with a few hundred miles on the street with full exhaust. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: a few dull tubes on my headers
[Re: nss guy]
#723117
06/13/10 07:09 PM
06/13/10 07:09 PM
fourgearsavoy
Rittman Ohio
Well I pulled the plugs from the pipes in question and they are white/gray but no aluminum yet I am going up a few sizes on the primaries as the front tubes are the ones getting dull #1 and #2 plugs look like they are more lean than the rest. Gus
[Re: DennisJ]
#723119
06/13/10 07:39 PM
06/13/10 07:39 PM
fourgearsavoy
Rittman Ohio
I just ran a 7.34 with very little traction with a 1.7 60' and my car usually done a 1.5 with a 9" tire.I think my new engine might be a little too much for a 9" tire.The ET Street radial went up in smoke instantly when I tried those.Then I put on a brand new pair of 9-28 ET slicks and it brought my 60 from 2.3 to 1.7. I may need a minitub and a 10.5 tire. Gus
[Re: fourgearsavoy]
#723120
06/13/10 07:48 PM
06/13/10 07:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You can try fattening that corner of the carb or you might need to balance the intake runners for more flow on those cylinders... if you had egt's in all of the tubes you could use them to set the intake balance
[Re: fourgearsavoy]
#723121
06/13/10 11:00 PM
06/13/10 11:00 PM
Posts: 43,257 Bend,OR USA
Cab_Burge
which intake, carbs and jetting are you using now Gus?
[Re: Cab_Burge]
#723122
06/13/10 11:08 PM
06/13/10 11:08 PM
fourgearsavoy
Rittman Ohio
Well Cab I have an Edelbrock Performer RPM,Pro-Max 1050 body 4150 style carb,82's and 4.5 PV primary and 90's and blocked PV in the rear. Gus
[Re: Cab_Burge]
#723124
06/14/10 08:54 AM
06/14/10 08:54 AM
fourgearsavoy
Rittman Ohio
Yeah maybe someday when I become rich and shameless until then I will just have to jet up a few clicks and read my plugs like always. Thanks Cab Gus
