How low can you get a car on CalTracs?
#722889
06/13/10 10:02 AM
06/13/10 10:02 AM
Posts: 1,015 Down South
DaKuda
Down South
Im on my third set of CalTracs and really like the way they work but cant stand the ride height. I have the lowered mono-leafs and still dont like the look. I moved the spring mounts another 1" up in the frame also. Is my only option ladder bars/4-link or could I use lowering blocks on the springs?
Re: How low can you get a car on CalTracs?
[Re: DaKuda]
#722890
06/13/10 10:07 AM
06/13/10 10:07 AM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have seen some mid 9 second NSS cars running lowering block with Cal-Tracs. It didn't look real strong to me but these guys run some serious HP numbers so what do I know. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: DaKuda]
#722893
06/13/10 10:17 AM
06/13/10 10:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Yes, and centered the rearend. These cars tend to have the rear off-centered
How much pre-load do you have.. that'll lift it
[Re: DaKuda]
#722897
06/13/10 10:44 AM
06/13/10 10:44 AM
MR_P_BODY
Yes, they are the 1" lowered ride height. That was the lowest when I got them.
Might want to call them and see if you can get a 2" lower set of springs... Caltracs seems to be a good company and tries to help out
[Re: Outlaw10_5]
#722902
06/13/10 11:05 AM
06/13/10 11:05 AM
MR_P_BODY
Been 1.25 60' @ 3200 on leafs/Caltracs with blocks on a 275 drag radial. You'll be fine...
I think he's looking for the looks of being lower (not positive)
[Re: Outlaw10_5]
#722903
06/13/10 11:12 AM
06/13/10 11:12 AM
DaKuda
Down South
Did the blocks change the way it acted? Would it still pull the front tires?
[Re: MR_P_BODY]
#722904
06/13/10 01:05 PM
06/13/10 01:05 PM
Posts: 860 Fort Pierce, FL
Outlaw10_5
Fort Pierce, FL
Perhaps, but he seems concerned of whether it will affect the setup. A 1" block will certainly lower the car, kinda goes without asking. I was posting a working example of one on blocks.
As far as the car (actually a truck) differences go with or without the blocks. The blocks put more leverage on the Caltrac and make them push harder. The end result depends on the tune. We can drag the bumper, spin, or leave with the wheels slightly off the ground. More tune-up than anything else. It didn't make it more prone to standing up tho, but we already had that worked out before.
[Re: DaKuda]
#722905
06/13/10 01:10 PM
06/13/10 01:10 PM
Thumperdart
State of confusion
Lowering blocks work fine...........have em on my heap and my buddy that makes em had em on his low 8-second car.
[Re: cbarracuda]
#722907
06/13/10 03:58 PM
06/13/10 03:58 PM
Posts: 6,295 U.S.
moparniac
U.S.
let me run out and snap a pic and see if you like my height!
Mopar Performance
[Re: moparniac]
#722908
06/13/10 04:23 PM
06/13/10 04:23 PM
Posts: 6,295 U.S.
moparniac
U.S.
it measures 22.5"s to the lip Caltracs -1 wit 3/4" lowering block! I wanted to see no tire above the rim!
Mopar Performance
