How low can you get a car on CalTracs? #722889
06/13/10 10:02 AM
06/13/10 10:02 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Im on my third set of CalTracs and really like the way they work but cant stand the ride height. I have the lowered mono-leafs and still dont like the look. I moved the spring mounts another 1" up in the frame also. Is my only option ladder bars/4-link or could I use lowering blocks on the springs?
Re: How low can you get a car on CalTracs? [Re: DaKuda] #722890
06/13/10 10:07 AM
06/13/10 10:07 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have seen some mid 9 second NSS cars running lowering block with Cal-Tracs. It didn't look real strong to me but these guys run some serious HP numbers so what do I know.
Gus
64 Plymouth Savoy
Dana 60
Re: How low can you get a car on CalTracs? [Re: DaKuda] #722891
06/13/10 10:09 AM
06/13/10 10:09 AM
pa
demongup Offline
demongup  Offline
pa
lowering blocks are ok . caltrac makes them.
did u raise the front and rear spring mounts into the frame?
Re: How low can you get a car on CalTracs? [Re: demongup] #722892
06/13/10 10:13 AM
06/13/10 10:13 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Yes, and centered the rearend. These cars tend to have the rear off-centered
Re: How low can you get a car on CalTracs? [Re: DaKuda] #722893
06/13/10 10:17 AM
06/13/10 10:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How much pre-load do you have.. that'll lift it
Re: How low can you get a car on CalTracs? [Re: MR_P_BODY] #722894
06/13/10 10:18 AM
06/13/10 10:18 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Zero, they are just bolted in loose with no adjustment.
Re: How low can you get a car on CalTracs? [Re: DaKuda] #722895
06/13/10 10:27 AM
06/13/10 10:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Are the springs you have the lowest they offer
Re: How low can you get a car on CalTracs? [Re: MR_P_BODY] #722896
06/13/10 10:39 AM
06/13/10 10:39 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Yes, they are the 1" lowered ride height. That was the lowest when I got them.
Re: How low can you get a car on CalTracs? [Re: DaKuda] #722897
06/13/10 10:44 AM
06/13/10 10:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Might want to call them and see if you can get
a 2" lower set of springs... Caltracs seems to be
a good company and tries to help out
Re: How low can you get a car on CalTracs? [Re: MR_P_BODY] #722898
06/13/10 10:49 AM
06/13/10 10:49 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
We have called them. The 1" lower spring is all they make at the time. I have also read on other posts that is doesnt work great running lowering blocks...
May just go back to ladder bars.
Re: How low can you get a car on CalTracs? [Re: MR_P_BODY] #722899
06/13/10 10:50 AM
06/13/10 10:50 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Afco rear spring sliders help about 3/4 of an inch
Re: How low can you get a car on CalTracs? [Re: joshking440] #722900
06/13/10 10:59 AM
06/13/10 10:59 AM
KENTUCKY
69CHARGERMD Offline
69CHARGERMD  Offline
KENTUCKY
I like the look now....
Re: How low can you get a car on CalTracs? [Re: 69CHARGERMD] #722901
06/13/10 11:01 AM
06/13/10 11:01 AM
Fort Pierce, FL
O
Outlaw10_5 Offline
Outlaw10_5  Offline
O
Fort Pierce, FL
Been 1.25 60' @ 3200 on leafs/Caltracs with blocks on a 275 drag radial. You'll be fine...
Re: How low can you get a car on CalTracs? [Re: Outlaw10_5] #722902
06/13/10 11:05 AM
06/13/10 11:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I think he's looking for the looks of being lower
(not positive)
Re: How low can you get a car on CalTracs? [Re: Outlaw10_5] #722903
06/13/10 11:12 AM
06/13/10 11:12 AM
Down South
DaKuda Offline OP
DaKuda  Offline OP
Down South
Did the blocks change the way it acted? Would it still pull the front tires?
Re: How low can you get a car on CalTracs? [Re: MR_P_BODY] #722904
06/13/10 01:05 PM
06/13/10 01:05 PM
Fort Pierce, FL
O
Outlaw10_5 Offline
Outlaw10_5  Offline
O
Fort Pierce, FL
(not positive)
Perhaps, but he seems concerned of whether it will affect the setup. A 1" block will certainly lower the car, kinda goes without asking. I was posting a working example of one on blocks.
As far as the car (actually a truck) differences go with or without the blocks. The blocks put more leverage on the Caltrac and make them push harder. The end result depends on the tune. We can drag the bumper, spin, or leave with the wheels slightly off the ground. More tune-up than anything else. It didn't make it more prone to standing up tho, but we already had that worked out before.
Re: How low can you get a car on CalTracs? [Re: DaKuda] #722905
06/13/10 01:10 PM
06/13/10 01:10 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Lowering blocks work fine...........have em on my heap and my buddy that makes em had em on his low 8-second car.
Re: How low can you get a car on CalTracs? [Re: Outlaw10_5] #722906
06/13/10 01:20 PM
06/13/10 01:20 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Re: How low can you get a car on CalTracs? [Re: cbarracuda] #722907
06/13/10 03:58 PM
06/13/10 03:58 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
let me run out and snap a pic and see if you like my height!
Mopar Performance
Re: How low can you get a car on CalTracs? [Re: moparniac] #722908
06/13/10 04:23 PM
06/13/10 04:23 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
it measures 22.5"s to the lip
Caltracs -1 wit 3/4" lowering block! I wanted to see no tire above the rim!
Mopar Performance
