Re: Dyno Results for my Stroker Six Pack [Re: 70BIRD] #715613
06/04/10 01:34 PM
06/04/10 01:34 PM
...gently down the stream
LAR_414 Offline
LAR_414  Offline
What kind of "stick" are you putting in it? What's the setup?
Re: Dyno Results for my Stroker Six Pack [Re: LAR_414] #715614
06/04/10 01:56 PM
06/04/10 01:56 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
I have an 18 spline A-833, Competition Plus shifter, Lakewood scatter shield and a McLeod clutch set-up and in the rear I have a 4:10 Dana with SS springs and I just got some Cal-track bars and the Rancho 9000 shocks that I still need to install.
Re: Dyno Results for my Stroker Six Pack [Re: 70BIRD] #715615
06/04/10 03:38 PM
06/04/10 03:38 PM
Connecticut
5126brl No more Offline
Connecticut
Great numbers!!!
Good luck with it!!!
I know my big problem is getting mine to leave the line with the six pack.
Re: Dyno Results for my Stroker Six Pack [Re: 5126brl No more] #715616
06/04/10 03:51 PM
06/04/10 03:51 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
great numbers....! Nick does nice work!
Re: Dyno Results for my Stroker Six Pack [Re: JACK1440] #715617
06/04/10 03:56 PM
06/04/10 03:56 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
what kind of flow #'s did Nick get out of the sr's?
Re: Dyno Results for my Stroker Six Pack [Re: JACK1440] #715618
06/04/10 10:06 PM
06/04/10 10:06 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Very nice power. That'll be fun.
Re: Dyno Results for my Stroker Six Pack [Re: BSB67] #715619
06/04/10 10:18 PM
06/04/10 10:18 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
sounds like a mid 10 sec. car! I'm surpirsed it likes to wind that high, too. Maybe the heads are resposible...he must really have them SRs flowing!
that's one cold(very cool) six pack!
Re: Dyno Results for my Stroker Six Pack [Re: B1Fish540] #715620
06/05/10 12:31 AM
06/05/10 12:31 AM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Did you ever get the cam info???
Inquiring minds want to know what cam is giving you ALL that power... LOL
Old Geezer Racing
Re: Dyno Results for my Stroker Six Pack [Re: 70BIRD] #715621
06/05/10 12:34 AM
06/05/10 12:34 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Great numbers.........I bet Cab`s grinnin ear to ear right now as he LOVES those 6-pack combos....
Re: Dyno Results for my Stroker Six Pack [Re: JACK1440] #715622
06/05/10 09:39 AM
06/05/10 09:39 AM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
As far as the heads go I believe he had the intakes flowing 329 cfm and the exhaust I believe was 234CFM. To aid in cam selection he flowed a couple of the ports with the intake manifold attached (after the Hughes stage II porting) and the flow varied from 276 cfm to 285 cfm.
I still don't have the build sheet but I'll be honest I'm not going to be able to give out the exact cam specs becuase Nick wants to keep that close to the vest (I'm not even going to get a copy of the cam card) but it is in the range of 650 lift and 274 duration.
Re: Dyno Results for my Stroker Six Pack [Re: 70BIRD] #715623
06/05/10 10:03 AM
06/05/10 10:03 AM
NC
440Jim Offline
440Jim  Offline
NC
Those are impressive numbers.
I am surprised the torque peak was below 4100 rpm while still making peak hp at 6700-6900 rpm. That is a wide power band. Also surprising the torque at 4900 was so different between with (633 lb-ft) and without (619 lb-ft) the air cleaner.
It would be worth knowing what headers were used on the dyno compared to in your car. That can make a noticable difference. Primary size and length.
You should be very happy with the results so far. I look forward to hearing the track results.
Re: Dyno Results for my Stroker Six Pack [Re: 440Jim] #715624
06/05/10 10:12 AM
06/05/10 10:12 AM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Thanks Jim!
In my car I have a set of TTI's step headers 2" to 2 1/8" and 3 1/2" collectors and a TTI 3" exhaust and on the dyno I'm not exactly sure but Nick said they weren't a step header but were similar sized anyway.
I probably won't make it to the track until Fall because I'm shooting to just be on the road by 4th of July weekend and by the time I finally get everything sorted out it'll be September.
Re: Dyno Results for my Stroker Six Pack [Re: 70BIRD] #715625
06/05/10 10:31 AM
06/05/10 10:31 AM
Central NC
gch Offline
gch  Offline
Central NC
Nice numbers!If you can get it to hook it will be a fun ride for sure.Can you say wheelstand??
I would imagine the Hughes porting on the intake helped it breathe to 7000rpm.I doubt a stock intake would have liked that.
Re: Dyno Results for my Stroker Six Pack [Re: gch] #715626
06/05/10 03:41 PM
06/05/10 03:41 PM
My stock unported low deck Eddy 6 pak intake on my 518 stroker 400 motor made peak HP at 5500 to 5700 RPM, peak torque at 4500 RPM, the car runs faster shifting it at 7000 RPM or above My 464 C.i. 440 block six pak motor likes to be shifted above 6000 RPM also, it has a stock unported Eddy six pak intake
Re: Dyno Results for my Stroker Six Pack [Re: Cab_Burge] #715627
06/07/10 02:53 PM
06/07/10 02:53 PM
Cool........ That's enough poop to push that car over 130MPH EASILY, even on a bad pass.........
I'm looking forward to track results too.......
Re: Dyno Results for my Stroker Six Pack #715628
06/07/10 02:54 PM
06/07/10 02:54 PM
tboomer Online work
tboomer  Online Work
I am with Wayne here....Can't wait to see track results!!
Re: Dyno Results for my Stroker Six Pack [Re: tboomer] #715629
06/07/10 03:21 PM
06/07/10 03:21 PM
Ohio
70BIRD Offline OP
70BIRD  Offline OP
Ohio
Thanks for all the positive comments guys!
I can't wait to see what it does either, I'll post an update when I do get out to the track.
Re: Dyno Results for my Stroker Six Pack [Re: 70BIRD] #715630
12/30/12 12:57 AM
12/30/12 12:57 AM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Just curious if this car's been run at the track yet????
If you can't handle the truth, you're living a lie.......
