Do Magnum serpentine water pumps run backwards CCW? #697598
05/14/10 07:59 AM
05/14/10 07:59 AM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
I just bought a new CAT water pump for an earlier model 360. The pump that was sent to me has an impeller that only pumps properly in a CCW rotation looking at the Pulley. The vendor swears they are all like that. Trying to get to the bottom of this.
Re: Do Magnum serpentine water pumps run backwards CCW? [Re: dmerc] #697599
05/14/10 08:14 AM
05/14/10 08:14 AM
Bama
BigDawg72 Offline
BigDawg72  Offline
Bama
It is my understanding that the magnum pumps do rotate opposite from the LA pumps due to the serpentine belt routing. I'm like 90% sure. Maybe someone who is 100% sure will chime in. I used the timing cover and water pump from my LA style engine when I put my magnum block together.
Re: Do Magnum serpentine water pumps run backwards CCW? [Re: BigDawg72] #697600
05/14/10 08:36 AM
05/14/10 08:36 AM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Bottom line, I need a CW pump and they sent me a CCW pump. Having a hard time trying to convince them it's wrong. They said send it back and pay a 15% restocking fee along with my shipping cost.
Re: Do Magnum serpentine water pumps run backwards CCW? [Re: dmerc] #697601
05/14/10 10:37 AM
05/14/10 10:37 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I have both pumps sitting on my bench. Magnum CCW, LA CW. The outlets for the pumps are totally different as well. Ask them how you are supposed to plumb it in now that your upper radiator hose does not reach.
Craig
Re: Do Magnum serpentine water pumps run backwards CCW? [Re: dmerc] #697602
05/14/10 10:48 AM
05/14/10 10:48 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
There is your problem...
Buy a better brand and bet you will get what you need...heck, rather have a parts store rebuild then a cat one..
Re: Do Magnum serpentine water pumps run backwards CCW? [Re: OzHemi] #697603
05/14/10 12:23 PM
05/14/10 12:23 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Yup, it's the last chinese knock off I'll buy. Ive learned my lesson. I'm going to the Chrysler dealer to see if they can spec a Heavy Duty water pump from say a police car from the 70's.
Re: Do Magnum serpentine water pumps run backwards CCW? [Re: dmerc] #697604
05/14/10 01:15 PM
05/14/10 01:15 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
most likely will be NS1 or only available as a reman, which most likely will be no different from what you could get at napa, carquest, etc.
AFAIK, there's no special "heavy duty" waterpump, just the 6 blade and 8 blade, and the determination on which to use is determined by application (A/C or non A/C, the water pump pulley is different sized between a/c and non a/c)
2017 Grand Cherokee Overland
Re: Do Magnum serpentine water pumps run backwards CCW? [Re: patrick] #697605
05/14/10 02:21 PM
05/14/10 02:21 PM
New Mexico
dmerc Offline OP
dmerc  Offline OP
New Mexico
Patrick, Ive also read that the 8 blade version is has a larger diameter impeller.
