Do Magnum serpentine water pumps run backwards CCW?
#697598
05/14/10 07:59 AM
05/14/10 07:59 AM
Posts: 1,061 New Mexico
dmerc
New Mexico
I just bought a new CAT water pump for an earlier model 360. The pump that was sent to me has an impeller that only pumps properly in a CCW rotation looking at the Pulley. The vendor swears they are all like that. Trying to get to the bottom of this.
Re: Do Magnum serpentine water pumps run backwards CCW?
[Re: dmerc]
#697601
05/14/10 10:37 AM
05/14/10 10:37 AM
Posts: 1,822 Colorado
denfireguy
Colorado
Bottom line, I need a CW pump and they sent me a CCW pump. Having a hard time trying to convince them it's wrong. They said send it back and pay a 15% restocking fee along with my shipping cost.
I have both pumps sitting on my bench. Magnum CCW, LA CW. The outlets for the pumps are totally different as well. Ask them how you are supposed to plumb it in now that your upper radiator hose does not reach. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: dmerc]
#697602
05/14/10 10:48 AM
05/14/10 10:48 AM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
There is your problem...
Buy a better brand and bet you will get what you need...heck, rather have a parts store rebuild then a cat one..
[Re: dmerc]
#697604
05/14/10 01:15 PM
05/14/10 01:15 PM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
most likely will be NS1 or only available as a reman, which most likely will be no different from what you could get at napa, carquest, etc.
AFAIK, there's no special "heavy duty" waterpump, just the 6 blade and 8 blade, and the determination on which to use is determined by application (A/C or non A/C, the water pump pulley is different sized between a/c and non a/c)
