Ritter Block VS R-3 Block
#697304
05/13/10 07:11 PM
05/13/10 07:11 PM
Posts: 465 Oconomowoc, WI.
Cudahlr
Oconomowoc, WI.
I'm looking at building a new engine, it will be set up for boost, don't know if im going turbo or procharger yet, but my question is what block would be the best to use, Ritter, r-3 or a prepped stock block, which I do have already, looking for around 650-700 horse when all is said and done. The rotating assembly will be all the good stuff, also this will be a street/strip engine running on 93 Thanks!
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp 1985 Harley Sportster Bobber 2006 Ram 2500 sport - The Cudahlr
Re: Ritter Block VS R-3 Block
[Re: Cudahlr]
#697305
05/13/10 07:16 PM
05/13/10 07:16 PM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
Back when I talked to Kent, you could get his block in a much taller deck than the R3 from what I remember. If that is worth anything to you is another story. Would be awesome for a huge stroker But if you are just building a 700 hp engine your R3 block will be just fine IMO
[Re: Cudahlr]
#697306
05/13/10 10:47 PM
05/13/10 10:47 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
I dont think the Ritter blocks are available. Are they? I knew someone that was interested but the production date kept getting pushed back so they just bought a siamesed bore R-3. I noticed alot of people that bought the nascar heads, rockers and intake setups are now selling them because they thought the Ritter block was going to make it easy to build a semi conventional chrysler block with killer heads. I think some people have given up on the block. Back to your origional question; I wouldnt use a production block for that kind of power. An R3 would work awesome. Especially a siamesed bore deal.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
[Re: PUNK]
#697307
05/13/10 11:37 PM
05/13/10 11:37 PM
Posts: 4,953 Houston, Texas
TheOtherDodge
Houston, Texas
FWIW, my buildup will be with a stock block. Partial fill 4 bolt billet main caps light weight rotating assembly (2.200 rods, .990 pins) Shooting for 700 hp
[Re: 408strokerdart]
#697314
05/16/10 01:22 AM
05/16/10 01:22 AM
Posts: 3,354 ohio
HEMIDARTS
ohio
I am waiting for some real results and to see how a high hp XR-2 will last. If all is well, I will be getting one for use with P7 heads. Anyone know how heavy the blocks are (tall deck)? Does anyone know if Ryan J has a lightening program from them yet? Also, are they dual pattern bellhousing?
I know they are heavy, but an R3 is heavy also.
Ryan can probally answer all your questions.
