Ritter Block VS R-3 Block #697304
05/13/10 07:11 PM
05/13/10 07:11 PM
Oconomowoc, WI.
Cudahlr Offline OP
Cudahlr  Offline OP
Oconomowoc, WI.
I'm looking at building a new engine, it will be set up for boost, don't know if im going turbo or procharger yet, but my question is what block would be the best to use, Ritter, r-3 or a prepped stock block, which I do have already, looking for around 650-700 horse when all is said and done. The rotating assembly will be all the good stuff, also this will be a street/strip engine running on 93
Thanks!
1968 Barracuda 360/727 11.20 @ 121 mph 421 rwhp
1985 Harley Sportster Bobber
2006 Ram 2500 sport - The Cudahlr
Re: Ritter Block VS R-3 Block [Re: Cudahlr] #697305
05/13/10 07:16 PM
05/13/10 07:16 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Back when I talked to Kent, you could get his block in a much taller deck than the R3 from what I remember. If that is worth anything to you is another story. Would be awesome for a huge stroker
But if you are just building a 700 hp engine your R3 block will be just fine IMO
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Ritter Block VS R-3 Block [Re: Cudahlr] #697306
05/13/10 10:47 PM
05/13/10 10:47 PM
Rancho Cucamonga, Calif.
P
PUNK Offline
PUNK  Offline
P
I dont think the Ritter blocks are available. Are they? I knew someone that was interested but the production date kept getting pushed back so they just bought a siamesed bore R-3. I noticed alot of people that bought the nascar heads, rockers and intake setups are now selling them because they thought the Ritter block was going to make it easy to build a semi conventional chrysler block with killer heads. I think some people have given up on the block.
Back to your origional question; I wouldnt use a production block for that kind of power. An R3 would work awesome. Especially a siamesed bore deal.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Ritter Block VS R-3 Block [Re: PUNK] #697307
05/13/10 11:37 PM
05/13/10 11:37 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
FWIW, my buildup will be with a stock block.
Partial fill
4 bolt billet main caps
light weight rotating assembly (2.200 rods, .990 pins)
Shooting for 700 hp
Re: Ritter Block VS R-3 Block [Re: TheOtherDodge] #697308
05/13/10 11:39 PM
05/13/10 11:39 PM
Houston, Texas
Houston, Texas
Re: Ritter Block VS R-3 Block [Re: PUNK] #697309
05/14/10 11:13 AM
05/14/10 11:13 AM
Vidor Texas
O
onyxba Offline
onyxba  Offline
O
Vidor Texas
Call Kent Ritter about the blocks, I will be picking mine up within a couple weeks. XR P7 block.
Re: Ritter Block VS R-3 Block [Re: onyxba] #697310
05/14/10 01:41 PM
05/14/10 01:41 PM
IL. Jerseyville
jg309 Offline
jg309  Offline
IL. Jerseyville
ryan, just got my xr-2 from kent, going to lighten, it only took about 3 mths. after deposit, going to build a 400,p7 headed circle track engine, going to have a lsm 4 clcy. timing swap on cam, looking for 850+ hp?
Re: Ritter Block VS R-3 Block [Re: jg309] #697311
05/14/10 05:52 PM
05/14/10 05:52 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
I would go with the Ritter block.
Ryan J can order them and others can also.
In the long run i think Ritters are cheaper with all the machining.
Re: Ritter Block VS R-3 Block [Re: HEMIDARTS] #697312
05/14/10 07:54 PM
05/14/10 07:54 PM
Out West
408strokerdart Offline
Out West
I am waiting for some real results and to see how a high hp XR-2 will last. If all is well, I will be getting one for use with P7 heads. Anyone know how heavy the blocks are (tall deck)? Does anyone know if Ryan J has a lightening program from them yet? Also, are they dual pattern bellhousing?
Re: Ritter Block VS R-3 Block [Re: Cudahlr] #697313
05/15/10 10:09 AM
05/15/10 10:09 AM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Ritters block for sure, unless you find an inexpensive R3.
Re: Ritter Block VS R-3 Block [Re: 408strokerdart] #697314
05/16/10 01:22 AM
05/16/10 01:22 AM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
I know they are heavy, but an R3 is heavy also.
Ryan can probally answer all your questions.
