Dominator JET EXTENSIONS..fitment issue
#697225
05/13/10 05:13 PM
05/13/10 05:13 PM
Posts: 767 NW PA
V10nacuda
NW PA
Well I pulled the fuel bowls off to double check what jets were on it & put on a set of jet extensions on it. Buttoned it back up & the rear floats hung open...Messed with the adjustment & nothing. pulled the extensions back off & it worked fine. What is going on??? are there different length jet extensions???
It's a dommmy 1150 & the fuel floats are notched, Do the 1150's come with jet extensions???? I really don't know where the extensions came from because the were in the box when I got it back from the dyno testing???
A friend mentioned he had a similar problem once & eneded up ordering the jet ext & floats as a package
Re: Dominator JET EXTENSIONS
[Re: V10nacuda]
#697226
05/13/10 05:20 PM
05/13/10 05:20 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
The float should black nitrophyl and have to round notch's cutout in the bottom of it, and the angle to clear the acc pump well valve. If its brass its wrong.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Dominator JET EXTENSIONS..fitment issue
[Re: V10nacuda]
#697227
05/13/10 05:40 PM
05/13/10 05:40 PM
Posts: 43,252 Bend,OR USA
Cab_Burge
What type jet extensions, screw in or press on and which floats do you have now?
[Re: bigtimeauto]
#697228
05/13/10 05:44 PM
05/13/10 05:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Yep.. gotta have the floats that are made for the extensions ... you can see the difference here also dont bother looking at these extensions, these are the press on style... use the screw in style http://www.summitracing.com/parts/AED-5896/?rtype=10
