Dominator JET EXTENSIONS..fitment issue #697225
05/13/10 05:13 PM
05/13/10 05:13 PM
NW PA
V10nacuda Offline OP
NW PA
Well I pulled the fuel bowls off to double check what jets were on it & put on a set of jet extensions on it. Buttoned it back up & the rear floats hung open...Messed with the adjustment & nothing. pulled the extensions back off & it worked fine. What is going on??? are there different length jet extensions???
It's a dommmy 1150 & the fuel floats are notched, Do the 1150's come with jet extensions???? I really don't know where the extensions came from because the were in the box when I got it back from the dyno testing???
A friend mentioned he had a similar problem once & eneded up ordering the jet ext & floats as a package
Re: Dominator JET EXTENSIONS [Re: V10nacuda] #697226
05/13/10 05:20 PM
05/13/10 05:20 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
The float should black nitrophyl and have to round notch's cutout in the bottom of it, and the angle to clear the acc pump well valve. If its brass its wrong.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Dominator JET EXTENSIONS..fitment issue [Re: V10nacuda] #697227
05/13/10 05:40 PM
05/13/10 05:40 PM
What type jet extensions, screw in or press on and which floats do you have now?
Re: Dominator JET EXTENSIONS [Re: bigtimeauto] #697228
05/13/10 05:44 PM
05/13/10 05:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Yep.. gotta have the floats that are made for the
extensions ... you can see the difference here
also dont bother looking at these extensions, these
are the press on style... use the screw in style
http://www.summitracing.com/parts/AED-5896/?rtype=10
Re: Dominator JET EXTENSIONS..fitment issue [Re: Cab_Burge] #697229
05/14/10 12:52 AM
05/14/10 12:52 AM
NW PA
NW PA
I have no idea what brand they are..they are a screw in type & the float is the black plastic with the notches cut or formed in.
Are their different lengths of extensions that wouldnt work with mismatched floats??
Re: Dominator JET EXTENSIONS..fitment issue [Re: V10nacuda] #697230
05/14/10 01:08 AM
05/14/10 01:08 AM
Santa Rosa,CA USA
67dodgeracer Offline
Santa Rosa,CA USA
I had that problem before,and filling the bowls slowly by turning the pump on and off repeatedly fixed the float from sticking.
Re: Dominator JET EXTENSIONS..fitment issue [Re: 67dodgeracer] #697231
05/14/10 04:47 AM
05/14/10 04:47 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
mine stuck as well--its the brass screw in ones. i just cut a bit of length off them till they would not hit the float.
works great now
