Fiberglass repair #69211
06/07/08 02:43 PM
06/07/08 02:43 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
I need to repair my fiberglass hood. The damaged areas are highlighted. Can I just reapply resin or should I put new matting and resin down? The fibers are loose due to theresin melting in these areas. The damage is only 1 layer deep.
Re: Fiberglass repair [Re: 73 SSP] #69212
06/07/08 03:15 PM
06/07/08 03:15 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
Anyone please. Are my questions that dumb or doesn't anyone know. If you don't know please say so. I'm frustrated enough without this.
Re: Fiberglass repair [Re: 73 SSP] #69213
06/07/08 07:43 PM
06/07/08 07:43 PM
Kansas
racincuda Offline
racincuda  Offline
Kansas
If it wer mine i woud grind off th bad area and lay in some mat without using too much resin, lay in several layer to fill in th ground areas
read up on doing this kind to start with
Re: Fiberglass repair [Re: 73 SSP] #69214
06/07/08 07:47 PM
06/07/08 07:47 PM
Kirkland, Washington
Pacnorthcuda Offline
You can repair that with JUST resin. It will be a 'cleaner' repair that will less noticable. If the area needs more strength you could add matting, but that will be a more noticable repair.
