66 charger,440. starts,won't start,starts,won't start. #690868
05/07/10 03:08 AM
05/07/10 03:08 AM
Murrayville, Illinois, usa
scotts66charger Offline OP
I have a 1966 Charger. 440, .30 over,headers BIG cam,Air gap manifold,holley 750 DP,electronic Ignition,new wiring from front to midway through the car (from "painless wiring" in california),etc. The problem is,just recently,the car will start fine,then I go to town,cruise a little, then go to lunch and turn the car off.After I have lunch, the car won't start. After a little while, it starts again. Sometimes it takes 20 minutes to start,or the other day, it wouldn't start for 2 days, then started just fine. It dosen't do it very often,but has happened more lately. I have a 3-5 year old"mini" starter on it. Do you think the starter is going bad, or maybe something else?? The battery is a new one.Anyone have a clue whats up? Thanx in advance. scott
Re: 66 charger,440. starts,won't start,starts,won't start. [Re: scotts66charger] #690869
05/07/10 03:26 AM
05/07/10 03:26 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
When you wrote that it won't start, do you mean that it spins over but will not run? Did you mean that turning the key results in NO response at all? For help you will need to give more info.
Re: 66 charger,440. starts,won't start,starts,won't st [Re: Kern Dog] #690870
05/07/10 12:53 PM
05/07/10 12:53 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
With no info , I would guess starter.Does it click? could be bad B+ on starter connection.
Re: 66 charger,440. starts,won't start,starts,won't start. [Re: Kern Dog] #690871
05/07/10 01:51 PM
05/07/10 01:51 PM
Sorry about that guys. Well,when I turn the key, i get nothing ! The door lights come on,etc,the alarm chirps when I turn the key to the off position. I replaced the key and switch, thinking it was that, but it still didnt turn over, so i put the old key/switch back in, and after aprox 4 hours, it started right up.. Hope that helps. scott
Re: 66 charger,440. starts,won't start,starts,won't start. [Re: scotts66charger] #690872
05/07/10 01:53 PM
05/07/10 01:53 PM
Itasca, Texas
Mad_Scientist Offline
Itasca, Texas
Sounds like a problem with the battery connection. Any corrosion at the starter?
69 Super Bee 440 5-speed
70 Dart Swinger 340 4-speed
69 Camaro SS 396 4-speed
66 Cutlass Convertilbe
70 Judge Ram Air III 4-speed
68 F-100 SWB
Re: 66 charger,440. starts,won't start,starts,won't start. [Re: scotts66charger] #690873
05/07/10 01:55 PM
05/07/10 01:55 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Have you checked to see if moving the shifter through the gears with the key in the start position made it turn over. Sometimes a slightly out of adjustment shift linkage will keep the neutral saftey switch form working.
Re: 66 charger,440. starts,won't start,starts,won't start. [Re: stumpy] #690874
05/07/10 01:58 PM
05/07/10 01:58 PM
I tried to move the shifter up and down through the D21 range, but didnt help. As far as the other post, the terminals are in excellant condition, no corosion,etc. What about the bendix? Dosen't that sit on top of the starter, and engage when I turn the key??
Re: 66 charger,440. starts,won't start,starts,won't start. [Re: scotts66charger] #690875
05/07/10 02:06 PM
05/07/10 02:06 PM
Grand Prairie,Texas
Grand Prairie,Texas
Next time try leaving the key on and jumping the starter relay on the fender. If it turns over then you can eliminate the starter as the problem.
Re: 66 charger,440. starts,won't start,starts,won't start. [Re: stumpy] #690876
05/08/10 03:09 AM
05/08/10 03:09 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
My buddies Road Runner did that, it was in the connection at the starter. The terminal was all stripped out and loosened up. Check the starter out for an electrical connection problem. If there is none it must be the starter itself.
Re: 66 charger,440. starts,won't start,starts,won't st [Re: stumpy] #690877
05/08/10 12:40 PM
05/08/10 12:40 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
1st place to start. Make sure its in park!
Just about took out my Dads 1st Charger doing this in drive!
