66 charger,440. starts,won't start,starts,won't start.
#690868
05/07/10 03:08 AM
05/07/10 03:08 AM
Posts: 188 Murrayville, Illinois, usa
scotts66charger
I have a 1966 Charger. 440, .30 over,headers BIG cam,Air gap manifold,holley 750 DP,electronic Ignition,new wiring from front to midway through the car (from "painless wiring" in california),etc. The problem is,just recently,the car will start fine,then I go to town,cruise a little, then go to lunch and turn the car off.After I have lunch, the car won't start. After a little while, it starts again. Sometimes it takes 20 minutes to start,or the other day, it wouldn't start for 2 days, then started just fine. It dosen't do it very often,but has happened more lately. I have a 3-5 year old"mini" starter on it. Do you think the starter is going bad, or maybe something else?? The battery is a new one.Anyone have a clue whats up? Thanx in advance. scott
Re: 66 charger,440. starts,won't start,starts,won't start.
[Re: Kern Dog]
#690871
05/07/10 01:51 PM
05/07/10 01:51 PM
scotts66charger
Sorry about that guys. Well,when I turn the key, i get nothing ! The door lights come on,etc,the alarm chirps when I turn the key to the off position. I replaced the key and switch, thinking it was that, but it still didnt turn over, so i put the old key/switch back in, and after aprox 4 hours, it started right up.. Hope that helps. scott
[Re: scotts66charger]
#690872
05/07/10 01:53 PM
05/07/10 01:53 PM
Posts: 322 Itasca, Texas
Mad_Scientist
Itasca, Texas
Sounds like a problem with the battery connection. Any corrosion at the starter?
69 Super Bee 440 5-speed 70 Dart Swinger 340 4-speed 69 Camaro SS 396 4-speed 66 Cutlass Convertilbe 70 Judge Ram Air III 4-speed 68 F-100 SWB
[Re: stumpy]
#690874
05/07/10 01:58 PM
05/07/10 01:58 PM
scotts66charger
I tried to move the shifter up and down through the D21 range, but didnt help. As far as the other post, the terminals are in excellant condition, no corosion,etc. What about the bendix? Dosen't that sit on top of the starter, and engage when I turn the key??
[Re: stumpy]
#690876
05/08/10 03:09 AM
05/08/10 03:09 AM
Posts: 5,163 CT
GTX MATT
CT
My buddies Road Runner did that, it was in the connection at the starter. The terminal was all stripped out and loosened up. Check the starter out for an electrical connection problem. If there is none it must be the starter itself.
[Re: stumpy]
#690877
05/08/10 12:40 PM
05/08/10 12:40 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Next time try leaving the key on and jumping the starter relay on the fender. If it turns over then you can eliminate the starter as the problem.
1st place to start. Make sure its in park! Just about took out my Dads 1st Charger doing this in drive!
