727 Diagnosis needed- give me your 2 cents *DELETED* *DELETED*
#686675
05/02/10 05:43 PM
05/02/10 05:43 PM
Posts: 423 DFW Texas
AHall
DFW Texas
not needed now- its toast
Re: 727 Diagnosis needed- give me your 2 cents
[Re: StukaJU87]
#686680
05/02/10 07:02 PM
05/02/10 07:02 PM
AHall
DFW Texas
welp, if that is the case, what does a good performance shop charge to rebuild a 727? $1000? $1500? Ugh, if its not one thing its another. (not concluding that is it, just speculating in order to prep the wife)
[Re: AHall]
#686682
05/02/10 10:37 PM
05/02/10 10:37 PM
Posts: 1,457 oklahoma
forphorty
oklahoma
[Re: forphorty]
#686683
05/02/10 10:47 PM
05/02/10 10:47 PM
Posts: 267 mpls,MN
dodgedakotaman
mpls,MN
Do you have the trans kickdown linkage hooked up and if so is it adjusted correctly? This can make a big difference. Make sure the kickdown lever moves freely. They like to get stuck and not move. Then the trans will shift funny.
[Re: dizuster]
#686685
05/02/10 10:57 PM
05/02/10 10:57 PM
AHall
DFW Texas
Man the thing sounds like a ski-boat.
Are you sure it was in 1st gear?
Sounds like it was just up flashed on the converter in high gear. The motor never really rev's up...
I was in "D"
It was revved up, it hit 5k rpm on that quick acceleration.
If I were to get the 727 rebuilt- are there any mods I should have done to it, or a shift kit installed or just go back with a stock rebuild? 440 is mild, just a cam and heads I'd say 480hp.
How can I tell if my kickdown linkage is stuck? On 2nd thought I don't think that's it- its felt like this for 2 years now.
[Re: AHall]
#686686
05/03/10 08:04 AM
05/03/10 08:04 AM
Posts: 15,487 Florida
scratchnfotraction
sounds like it was slipping to me.. also sounds like the TC is to high on stall also why so much? I would use a tight 3000 stall from turbo action
[Re: scratchnfotraction]
#686687
05/03/10 08:15 AM
05/03/10 08:15 AM
AHall
DFW Texas
why so much?
It's a hughes 3000 stall
[Re: AHall]
#686690
05/03/10 08:39 AM
05/03/10 08:39 AM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
question-
ON a 727 rebuild- is it simple enough a regular(local) transmission shop can rebuild it or would you take it to a performance transmission specialist?
If ANY trans shop can't rebuild a 727 they have no business owning a shop.
[Re: AHall]
#686692
05/03/10 09:27 AM
05/03/10 09:27 AM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
Sure sounds like it is slipping. If the car has been doing that since you got it, it could be that the kickdown linkage has always been out of adjustment and needs adjusting. I would start with that. You could be putting "just" enough pressure into it to make it seem kinda normal. At WOT make sure the lever on the trans is all the way back. If that seems to improve it some, next I would call a reputable torque converter company and give them your cam specs and see what they recommend for a torque converter. 3000 seems high to me. If your running a mild cam I would think a stock stall or maybe 2200-2400 would be sufficient. There are a multitude of factors, car weight, cam (power band), rear gears, and of course usage. IF it is going to be mostly a street car then in my opinion 3000 is to high. In 1973 Chrysler pushed the limits, much to everyone's suprise, when they put a higher stall converter in production vehicles which was still less than 3000. A given torque converter may stall at 2,500 rpm behind a small block with 300 lb-ft of torque, but provide 3,000 rpm before reaching stall speed behind a 440 which belts out 450 lb-ft of torque at stall rpm. It varies.
