Page 3 of 4 1 2 3 4
Re: My prochargerd 440 [Re: Mr500_wedge] #68450
06/19/08 10:00 PM
06/19/08 10:00 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Mr500, that looks awesome. I want a procharger sooooo bad!!
Re: My prochargerd 440 [Re: moparbob498] #68451
06/22/08 04:45 AM
06/22/08 04:45 AM
SWEDEN
Mr500_wedge Offline OP
SWEDEN
i have to say that is a really SWEET set-up...and it basically fits under the hood...i may have missed
this,.but does it run on pump gas? when i built my 500" i was debating on a set-up like that or a roots blower....went with the roots because my dad wanted
to always build & run one.....but damn yours is sweet i say again.....here's a pic of mine anyhow
Thanks,
Yes I run it with pump gas 98octan. I had to lower the compression from 11,5 to around 9,7 to prevent detonation when i installed the procharger,
Re: My prochargerd 440 [Re: ProSport] #68452
06/22/08 04:46 AM
06/22/08 04:46 AM
SWEDEN
SWEDEN
Re: My prochargerd 440 [Re: Mr500_wedge] #68453
06/22/08 09:23 AM
06/22/08 09:23 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Looks great, my Sweedish fellow. Is that belt cogged ? Do you think you get any slippage if its not ? Looks great..Do you really take it on the ice ??
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: My prochargerd 440 [Re: sunroofgtx] #68454
06/23/08 06:10 AM
06/23/08 06:10 AM
SWEDEN
SWEDEN
The ice thing whas just a joke
I had some small problem on the dyno that the belt did slippage a litle until I figure out how to set up the tensioner, after that it workt fine
Re: My prochargerd 440 [Re: Mr500_wedge] #68455
08/22/09 08:48 AM
08/22/09 08:48 AM
SWEDEN
SWEDEN
Little update,
Got me a set of new rims and wheels, Hoosier pro dot and Centerline warrior rims.
I am quite satisfied with them.
But now I have a new problem, When I give more than half throttle with the new grip I have, the rear wheels rub the inner fender, so the rear axle move a bit.
I have tighten all the bolts to the rear suspension/axle but It still move, so I am thinking off the Cal track system to my car?
Anyone had the same problems? Let me hear and se your solutions.
Thanks/
Toni
Re: My prochargerd 440 [Re: Mr500_wedge] #68456
08/22/09 08:49 AM
08/22/09 08:49 AM
SWEDEN
SWEDEN
another
Re: My prochargerd 440 [Re: Mr500_wedge] #68457
08/22/09 08:50 AM
08/22/09 08:50 AM
SWEDEN
SWEDEN
one more
Re: My prochargerd 440 [Re: Mr500_wedge] #68458
08/22/09 08:53 AM
08/22/09 08:53 AM
SWEDEN
SWEDEN
las one with my GF's Camaro
Re: My prochargerd 440 [Re: Mr500_wedge] #68459
08/22/09 09:17 AM
08/22/09 09:17 AM
SWEDEN
SWEDEN
Anyone have some photos of Caltracs installed on a E-body ?
Thanks//
Toni
Re: My prochargerd 440 [Re: Mr500_wedge] #68460
08/22/09 09:49 AM
08/22/09 09:49 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
the cal tracks ride lower dont thay?can you adjust the shock setting?i did not go back and read all of your post to see.i will now.
Re: My prochargerd 440 [Re: blownzoom440] #68461
08/22/09 09:57 AM
08/22/09 09:57 AM
SWEDEN
SWEDEN
i have the Be Cool adjusted shocks on my car and new hemi leaf springs on my car. If the Caltracs whill lower my car , then i have a problem :-(
Re: My prochargerd 440 [Re: Mr500_wedge] #68462
08/22/09 10:07 AM
08/22/09 10:07 AM
ELYRIA,OH
ELYRIA,OH
the springs only hold the car up so you may be able to adjust the height with longer shackles[edit] with the caltracs!.the shock will help the squating movement and plant the tires.did you try a stiffer shock setting?i am sure you know about springs.
Re: My prochargerd 440 [Re: blownzoom440] #68463
08/22/09 10:11 AM
08/22/09 10:11 AM
SWEDEN
SWEDEN
i adjusted the shocks to max stiffnes, but the rear axle still move so the tires rub the inner fender, :-(
Re: My prochargerd 440 [Re: Mr500_wedge] #68464
08/22/09 10:15 AM
08/22/09 10:15 AM
ELYRIA,OH
ELYRIA,OH
i bet your tires realy rub going around a corner.
Re: My prochargerd 440 [Re: blownzoom440] #68465
08/22/09 10:22 AM
08/22/09 10:22 AM
SWEDEN
SWEDEN
yes,then too, and when i give it trottle.
what is the solution?
Re: My prochargerd 440 [Re: Mr500_wedge] #68466
08/22/09 10:25 AM
08/22/09 10:25 AM
ELYRIA,OH
ELYRIA,OH
i should let the chassis people handle this.
as far as i know for the corners an anti roll bar.
Re: My prochargerd 440 [Re: Mr500_wedge] #68467
08/22/09 10:36 AM
08/22/09 10:36 AM
ELYRIA,OH
ELYRIA,OH
on your 1st post you wrote:Maybe I Chicken out a little so we only pull it to 6000rpm and 1.1 pounds off Boost, but I didn’t want to risk anything on the dyno, so the number is ok anyway, 774,8 ft 5000rpm and 818Hp 5800rpm and then the valve start to open at 1.1pounds.]
did you mean 1.1 Bar of psi?just over 14lbs of boost.
Re: My prochargerd 440 [Re: blownzoom440] #68468
08/22/09 10:54 AM
08/22/09 10:54 AM
SWEDEN
SWEDEN
i wrothe the wrong number on my first post. i run it 0,5 bar of boost on the dyno att 6000rpm
(7.252 psi)
sry
Re: My prochargerd 440 [Re: Mr500_wedge] #68469
08/22/09 11:00 AM
08/22/09 11:00 AM
ELYRIA,OH
ELYRIA,OH
Thanks.
how much tire to fender room do you have[both sides of tire?]
Page 3 of 4 1 2 3 4
