Re: 383 B cheapo stroker combo... help!
[Re: ph23vo]
#683675
04/29/10 04:02 PM
04/29/10 04:02 PM
Posts: 5,080 organ
maximum entropy
organ
you never really know until you start mocking it up. plan on problems, that way you won't be disappointed. 440source has several kits for 383. i'll prolly end up building a long rod 438 with my aulde 383 block. check the 440source website. even if you don't get one of their kits, there's a lot of good info there.
