383 B cheapo stroker combo... help! #683672
04/29/10 03:30 PM
04/29/10 03:30 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
Diamond flat tops , 1.320 CH , 4.280 bore , .990 pin . chevy 6.700 rods, 3.90 crank should i have any clearance problems? also using stealth heads any opinions? dan
Re: 383 B cheapo stroker combo... help! [Re: ph23vo] #683673
04/29/10 03:32 PM
04/29/10 03:32 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
legend I beam rods 199.00, scat H beam 269.99 or eagle h beam 369.99??? who,s crank would you use??
Re: 383 B cheapo stroker combo... help! [Re: ph23vo] #683674
04/29/10 04:01 PM
04/29/10 04:01 PM
Aurora Colorado
BELVEDERE67 Offline
mopar addict
BELVEDERE67  Offline
mopar addict
Aurora Colorado
As far as the rods, you normally get what you pay for. Scat seems to have good comments on this board. Eagle is what I have and they have been good so far. Anything you buy has to be checked tho. As far as the crank, I really don't know. I bought mine as a redone 440 offset ground crank for a b-engine. There may be better ways now tho.
Good luck
Re: 383 B cheapo stroker combo... help! [Re: ph23vo] #683675
04/29/10 04:02 PM
04/29/10 04:02 PM
organ
maximum entropy Offline
organ
you never really know until you start mocking it up. plan on problems, that way you won't be disappointed. 440source has several kits for 383. i'll prolly end up building a long rod 438 with my aulde 383 block. check the 440source website. even if you don't get one of their kits, there's a lot of good info there.
Re: 383 B cheapo stroker combo... help! [Re: maximum entropy] #683676
04/29/10 04:23 PM
04/29/10 04:23 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
...or there is this guy that has been posting on Craigslist in St. Louis for several months...
http://stlouis.craigslist.org/pts/1702227879.html
Re: 383 B cheapo stroker combo... help! [Re: Blues_Cuda] #683677
04/29/10 04:27 PM
04/29/10 04:27 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
keep em coming guys... i,m sure there,s lots more real real low buck ways to build like the CL guy...
Re: 383 B cheapo stroker combo... help! [Re: ph23vo] #683678
04/29/10 06:01 PM
04/29/10 06:01 PM
White House,TN
stroked470 Offline
stroked470  Offline
White House,TN
I used a set of Eagle H beams 6.76 with Diamond pistons and a 440 3.75 stroke crank all I had to do was notch the bottom of the cylinders a little to clear the rod bolts.
Re: 383 B cheapo stroker combo... help! [Re: stroked470] #683679
04/29/10 06:24 PM
04/29/10 06:24 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
would it be less expensive to have a 440 crank offset ground to 3.89-91 w BBC journal size since i have a free one? whats the cost on doing that? anyone gone that route? dan
Re: 383 B cheapo stroker combo... help! [Re: ph23vo] #683680
04/29/10 10:24 PM
04/29/10 10:24 PM
Mesa, AZ
Bill_T Offline
Bill_T  Offline
Mesa, AZ
I have slowly been putting together all the parts for this combo and am just about ready to put it together. 383 block, .040 over. Diamond pistons, K1 6.7 rods BBC journal and Eagle 3.9 crank. The rods came from DRAM. The crank was on clearance from Mancini, and had BBM rod journals, which I had turned down locally - around 200$. Can't report anything else because it is not together yet. Depends on your definition I suppose, but I am not convinced its going to end up being all that "cheapo".
Re: 383 B cheapo stroker combo... help! [Re: Blues_Cuda] #683681
04/29/10 10:54 PM
04/29/10 10:54 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Thats the first time I've heard of using buick rods in a mopar.
Re: 383 B cheapo stroker combo... help! [Re: ph23vo] #683682
04/29/10 10:57 PM
04/29/10 10:57 PM
I have done that, hundreds of other Mopar racers have to back in the day before the cheaper stroker cranks came out. I have two 440 motors that I built in the last three years that used the 3.910 stroke, one was a forge steel 440 magnum crank that I had done in SO Ca five or six years ago. The other was a BRC race crank that had the same 3.91 stroke that I got on a deal from a crankshaft grinding company in SO CA The 440 offset grinding cost me 325.00 including having it heat treated (Nitrited)after the grinding That motor is in my car now, I used a set of 7.100 long BB Chevy H beam rods and a set of Diamond pistons in that motor, the other motor got a set of Eagle 7.100 long BB Chevy rods also and I used a set of KB forged pistons in that motor, it made 720 HP at 7000 RPM on a DTS engine dyno. It is a bracket race motor with a lot of good parts. Mine is a pump gas 6 pak street motor in a 1971 Duster that runs low elevens cork up on Oregon pump gas, it is for sell for the right price
Re: 383 B cheapo stroker combo... help! [Re: Cab_Burge] #683683
04/30/10 12:06 AM
04/30/10 12:06 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
thanks guys appr the info.. if anyone see,s or hears of any deals on cranks rods etc ..closeouts lmk i would rather buy from someone needing the $$$ and to get rid of parts .. prefer 3.9 crank BBC rod size, 6.700 BBC rods good pistons [which i have a line on now] stealth heads dan
Re: 383 B cheapo stroker combo... help! [Re: ph23vo] #683684
04/30/10 03:32 PM
04/30/10 03:32 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Dan as long as the crank is a true low deck piece , meaning it doesn't have huge hemi or 440 counterweights , there are no clearance issues. I did no grinding on my 383 and didn't have to use a stroker windage tray either, a standard issue milodon tray clears no problem.
I'd use either the scat or the eagle rod .
Re: 383 B cheapo stroker combo... help! [Re: JohnRR] #683685
04/30/10 04:08 PM
04/30/10 04:08 PM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
thanks john i was leaning towards scat but am still doing some looking dan
Re: 383 B cheapo stroker combo... help! [Re: ph23vo] #683686
05/01/10 07:18 AM
05/01/10 07:18 AM
SW WI
cudacustoms1 Offline
SW WI
I have a set of brand new wiseco piston that I can't use I would sell cheap! 4.310 bore, 1.705 comp height .990 pin size. If anyone can use them give me a call for more details. 608 485 0760 thanks chad
Re: 383 B cheapo stroker combo... help! [Re: cudacustoms1] #683687
05/01/10 09:56 AM
05/01/10 09:56 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Met a guy here in Charlotte the other night with a 68 383 Charger. He wants to build a stroker and he has a 440 block but I advised him to build his 383 as a stroker just to keep the engine bay looking oem!
Nothing wrong with the 4.25 bore.....7000 hp Blown Nitro Hemis only run a ~4.18" bore these days!!
WIZE
In Car:
Re: 383 B cheapo stroker combo... help! [Re: Streetwize] #683688
05/03/10 10:38 AM
05/03/10 10:38 AM
renton, Washington
ph23vo Offline OP
ph23vo  Offline OP
renton, Washington
i,m leaning towards a 3.9 crank, 6.700 chevy rods in my 383... since it will have stock intake and exh..what cam should i run to have a smooth idle when its WARM? will have 3:55 gears more than likely..also can i use say a 750 holley and stick on the factory side hung bowls? [so it still looks like a mopar carb] thanks guys dan
