Re: Muscle car oil [Re: intragration] #671206
04/18/10 08:09 AM
04/18/10 08:09 AM
N. of 8mile, S. of heaven
Spike Offline
Go Blue!!
Spike  Offline
Go Blue!!
Oil provides a barrier between moving parts in an engine. It keeps parts from rubbing together thus reducing heat and wear. Without this barrier engine parts would be welded together in no time.
Older cars with flat tappet cams need Zinc. Period. Most modern oils have reduced zinc because of roller cams and alleged damage that zinc causes to catalytic converters.
I can never understand guys that will spend a fortune on paint, tires, motor builds, etc and then act like they won the lotto when they find a sale on Wally world oil.
The oil is the blood of your engine, of any engine for that matter. Find the right oil for your application and use it.
Re: Muscle car oil [Re: fury4speed] #671207
04/18/10 08:26 AM
04/18/10 08:26 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
I think the Valvoline VR 1 20/50 has or close to the highest Zinc content for off the shelf Oil at your local parts stores , but if you want some Oil with all the good stuff in it use BradPenn Oil , they also make a Break-in Oil. The BradPenn also has more Zinc in it than the Joe Gibbs Oil if I remember right.
http://www.bradpennracing.com/
And here is a Brad Penn analysis I had done over a year ago,only way to be sure.Go compare,most others aren't even close.
Re: Muscle car oil [Re: Big Sexy 70] #671208
04/18/10 09:22 AM
04/18/10 09:22 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
I used valvoline and took out my comp cam and lifter after about 15000,...I'm now using brad penn oil....get it for about 40 a case
Re: Muscle car oil [Re: Big Sexy 70] #671209
04/18/10 11:33 AM
04/18/10 11:33 AM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Fact vs Opinion click here to read up on some oil analysis. Better than opinions and misinformation...
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Muscle car oil [Re: Junky] #671210
04/18/10 01:13 PM
04/18/10 01:13 PM
midwest
I
intragration Offline
I
midwest
The OP specifically asked for opinions...although in this case, most of the opinions stated are also fact.
Re: Muscle car oil [Re: intragration] #671211
04/18/10 01:56 PM
04/18/10 01:56 PM
Cookeville
Chilort Offline
Will Work For Mopars
Chilort  Offline
Cookeville
I'd heard the hydraulic flat tappet cams required more zinc so I always dumped the VR1 into my 440 at every oil change. Then I heard that even VR1 might not have enough zinc. When I rebuilt my engine I installed a flat tappet hydraulic Lunati cam and lifters.
You'll never believe what I did next. I called the cam maker! Whoa, right?
VR1 is adequate.
And if you don't want to run 20w-50 you can get some of the local parts stores to order cases of the other weights. Valvoline makes the VR1 in 10w-30 and 10w-40. My local O'Reilly will order cases but AutoZone won't. You also have to find the right person at these types of stores because, or course, some of the people are new and clueless.
Re: Muscle car oil [Re: Chilort] #671212
04/18/10 02:13 PM
04/18/10 02:13 PM
OK
70SWGR Offline
70SWGR  Offline
OK
Where do you find the ZDDP additive?Is that the actual name on the label?Is the Comp additive the same thing?
Re: Muscle car oil [Re: 70SWGR] #671213
04/18/10 02:21 PM
04/18/10 02:21 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
ZDDPlus is available on Ebay. The stuff comes in a 4 oz bottle for about $10. Its something like 57,00PPM of Zincdilithiophosphate (sp?) so if you do the math even 1/2 bottle is enough for an oil change IF you're starting with an oil that contains, say, at least 900PPM to start with.
I've heard from several sources that Comp Cams additive is actually a mega-doze of Moly. Which does work for the intended purpose.
I use ZDDPlus.
Re: Muscle car oil [Re: Pacnorthcuda] #671214
04/18/10 08:46 PM
04/18/10 08:46 PM
IA
landon1 Offline
landon1  Offline
IA
i ordered 2 cases of VR1 10-30 from O'Reilly's while building my 440. only $4 per quart
'71 Satellite Sebring 440
Re: Muscle car oil [Re: landon1] #671215
04/18/10 09:58 PM
04/18/10 09:58 PM
PA
Big Sexy 70 Offline OP
PA
Well just told my wife I gotta run a roller cam now.
Re: Muscle car oil [Re: 62maxwgn] #671216
04/19/10 09:16 AM
04/19/10 09:16 AM
Eau Claire, WI
ResQ911 Offline
super gas
ResQ911  Offline
super gas
Eau Claire, WI
I would not use anything else............
Re: Muscle car oil [Re: ResQ911] #671217
04/19/10 01:37 PM
04/19/10 01:37 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I use 15w40 Rotella and a little bottle of ZDDP additive I get at Summit for $10 a shot. Three different machine shop owners have told me that was fine and that synthetic oils were not necessary.
This stuff
http://www.summitracing.com/parts/CRO-86092/
