Muscle car oil #671186
04/15/10 10:52 PM
04/15/10 10:52 PM
PA
Big Sexy 70 Offline OP
PA
This new stuff they are selling for 8.00 a quart. Supposedly has stuff for older cams.. Whats your guys opinion? Good or Gimick?
Re: Muscle car oil [Re: Big Sexy 70] #671187
04/16/10 01:07 AM
04/16/10 01:07 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
Ive seen this new oil looks very expensive for a name ,I belive it has more zinc than conv. oil and you can replace that with a good additive. my oppinion save the money.
Re: Muscle car oil [Re: moparsquid] #671188
04/16/10 01:32 AM
04/16/10 01:32 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Valvoline VR Max is available for just over $ 4.00 per Qt. Check it out.
Re: Muscle car oil [Re: Big Sexy 70] #671189
04/16/10 11:33 AM
04/16/10 11:33 AM
USA
JoesMopar Offline
JoesMopar  Offline
USA
GTX 20W-50, a bottle of Lucas or Comp Cams break in lube for 10-12 bucks and call it done.
Re: Muscle car oil [Re: Big Sexy 70] #671190
04/16/10 12:04 PM
04/16/10 12:04 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
It probably does what it says. I'm of the "Old School" way of thinking with muscle engines. They need more zinc than modern engines do. With that, for many, many, years, I've been using Rotilla T 15W-40 with 2 bottles of STP. (my engine holds 9 quarts with filter). One bottle of STP treats 5 quarts.
Just my
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Muscle car oil [Re: 68LAR] #671191
04/16/10 12:30 PM
04/16/10 12:30 PM
how old of a cam? I think most of those 20-30-40 year old cams have been replaced by now. so unless the cam companys are still using steel that was smelted eons ago, how is $8/quart oil going to help?
Re: Muscle car oil #671192
04/16/10 01:13 PM
04/16/10 01:13 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
It's not the steel material that's the issue, it's the lubrication properties of the oil, and the fast that many of us are running more aggressive cams than stock. Plenty of guys are wiping new cams, so why take the chance?
Re: Muscle car oil [Re: DaytonaTurbo] #671193
04/16/10 01:26 PM
04/16/10 01:26 PM
at $8/quart? I'm sure todays cam/lifters with the micro-finishing on them, and the porous nature of the metal that they are using easily compensates for any 'lack' of zinc. also, who much of an advantage is say 1000ppm vs what?? 1500ppm in today 'high' zinc race oil. not trying to start a pissing match. just curious.
Re: Muscle car oil [Re: 68LAR] #671194
04/16/10 01:44 PM
04/16/10 01:44 PM
midwest
I
intragration Offline
I
midwest
Lar, Rotella DOES NOT have the zinc that it used to have. It used to be the old stand-by in regards to zinc. (ZDDP) It now has the same amount of zinc as any other typical oil now. Someone I know now has a very low lift cam as a result of Rotella.
The two oils that I've looked into are the Valvoline VR and Joe Gibbs. I went with Valvoline VR because it's not synthetic. It seems to have enough zinc, and it's relatively inexpensive too.
Re: Muscle car oil [Re: intragration] #671195
04/16/10 02:10 PM
04/16/10 02:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Warhawk, the new cams still have a tendency to wipe lobes without a greater amount of zinc than the standard oil contains. I'm not a chemist just a guy that's been building engines since the mid 60s and I will not break in a new motor or cam without adding zinc to the oil. So far I have only lost one cam.
Re: Muscle car oil [Re: intragration] #671196
04/16/10 02:11 PM
04/16/10 02:11 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I used the Valvoline VR1 20w50 last change, it looked pretty thick but seems to work well, ie good pressure, and lower valvetrain noise.
Re: Muscle car oil [Re: stumpy] #671197
04/16/10 02:17 PM
04/16/10 02:17 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Valvoline VR1 20w50 is what I run. I have had oil samples of it new and used in my car. It has 1100 to 1200 ppm zinc from the samples I have had taken.
Re: Muscle car oil [Re: Azzkikrcuda] #671198
04/17/10 12:43 AM
04/17/10 12:43 AM
PA
PA
Well greatly appreciate the comeback. I myself run GTX 20w-50 and have been very happy with it. I just dont buy into all the hoopla about some of these oils. My oppinion is if you keep it changed often you wont have any trouble. Thanx guys.
Re: Muscle car oil [Re: Big Sexy 70] #671199
04/17/10 02:08 AM
04/17/10 02:08 AM
midwest
I
I
midwest
Hey Big, I agree about not buying into hoopla, but please make sure you read up on and understand about zinc and ZDDP in oil. Sometimes, the hoopla is intended to cover up the fact that the zinc level has been cut back. Our cars were designed and built with flat tappets, and oil always had sufficient zinc to protect them. About 5 years ago, zinc levels in typical oils were reduced, to protect catalytic converters in newer cars. At this time, problems started showing up with the older cars. The problems are usually in the form of mysteriously failing camshafts. Changing your oil frequently won't compensate for the fact that there just isn't enough of this specific lubricant in the oil. Eventually, the current API standard will be replaced with another, and zinc levels may drop even lower at that time.
In my experience, and this is strictly anecdotal, but the less forthcoming an oil manufacturer is about the zinc content of their oil, the less zinc their oil contains. Conversely, if the oil is advertised as containing sufficient zinc, and as suitable for older cars, this is usually a good sign. Again, this is just my opinion.
Re: Muscle car oil [Re: intragration] #671200
04/17/10 02:22 AM
04/17/10 02:22 AM
Illinois
V
v10 Offline
v10  Offline
V
Illinois
I was going to post the same thing
Re: Muscle car oil [Re: v10] #671201
04/17/10 09:21 AM
04/17/10 09:21 AM
Locomotion Offline
Locomotion  Offline
Personally I prefer Amsoil products and use their Dominator series oil. But whatever your preference is, this bulletin outlines the issues with most common, current motor oil. Comp Cams and other companies have provided similar information.
Amsoil tech bulletin on oil and flat tappet cams.
Amsoil source and added info.
Since synthetics are not recommended for break-in, I'll continue to use my old stock of conventional oil but still add a zinc additive for insurance. Then switch to high zinc Amsoil.
Re: Muscle car oil [Re: Locomotion] #671202
04/17/10 09:34 AM
04/17/10 09:34 AM
fury4speed Offline
fury4speed  Offline
I think the Valvoline VR 1 20/50 has or close to the highest Zinc content for off the shelf Oil at your local parts stores , but if you want some Oil with all the good stuff in it use BradPenn Oil , they also make a Break-in Oil. The BradPenn also has more Zinc in it than the Joe Gibbs Oil if I remember right.
http://www.bradpennracing.com/
Re: Muscle car oil [Re: fury4speed] #671203
04/17/10 11:51 PM
04/17/10 11:51 PM
East Central Illinois
jeff57 Offline
jeff57  Offline
whats your motor worth? it don't matter what it cost if its what your engine needs to live! zinc is the key, i don't like $55 a case either,but i'm not taking a chance to save $20. jeff57
Re: Muscle car oil [Re: jeff57] #671204
04/17/10 11:55 PM
04/17/10 11:55 PM
PA
PA
But like posted earlier in the thread. Dont you think todays cams are made from alot better materials than the used to be?
Re: Muscle car oil [Re: Big Sexy 70] #671205
04/18/10 03:59 AM
04/18/10 03:59 AM
midwest
I
I
midwest
It doesn't have anything to do with how good the cams are made, it's still very demanding metal-to-metal direct friction versus the rollers in all modern engines. The need for zinc has practically been eliminated in these modern motors. For the rest of us, there is a quick solution: specialty oil (or additives) that contain sufficient zinc. It's that simple.
