B-1 Header gaskets???? Is there such a beast??? #670447
04/15/10 01:16 PM
04/15/10 01:16 PM
NW PA
V10nacuda Offline OP
NW PA
Well I pulled the motor out to clearance the frame rail & shock tower to allow for more room to install the headers.
I know alot of you guy's use just silicone & NO GASKET. But I don't know how tight your engine bay is But I have to install the headers in the correct order loos without bolts & then once they are all in place put them up to be bolted on....There is no room to install any silicone.
So today I put a set of Mr gasket ultras on & as expected the port was too small. I can enlarge the port in trhe gasket to match....
DOES ANYONE HAVE ANY OTHER SOLUTIONS?????
FOr those that just use silicone do you install it wet???????? Or let it set up & then install????
V10
Re: B-1 Header gaskets???? Is there such a beast??? [Re: V10nacuda] #670448
04/15/10 01:25 PM
04/15/10 01:25 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Yes you can open up the Mr. G Ultra's to match your port.
Sorry I don't have any exhaust gaskets for your application.
Re: B-1 Header gaskets???? Is there such a beast??? [Re: roadhazard] #670449
04/15/10 01:52 PM
04/15/10 01:52 PM
sg66mopar Offline
sg66mopar  Offline
When I ordered my B1s from Koffel they told me there's no gasket specifically for these heads. The Mr. Gasket and an Exacto knife is probably the answer.
Re: B-1 Header gaskets???? Is there such a beast??? [Re: V10nacuda] #670450
04/15/10 02:18 PM
04/15/10 02:18 PM
Contact SCE gaskets and see if they have them now, if not they will make them if you send a sample to them They offer both copper and regular materials on there gaskets
Re: B-1 Header gaskets???? Is there such a beast??? [Re: Cab_Burge] #670451
04/15/10 02:24 PM
04/15/10 02:24 PM
land of the free
ts racer Offline
ts racer  Offline
land of the free
Call Flatout. They have them.
Re: B-1 Header gaskets???? Is there such a beast??? [Re: ts racer] #670452
04/15/10 03:52 PM
04/15/10 03:52 PM
sg66mopar Offline
sg66mopar  Offline
Did a search and came up with nothing related to drag racing or Mopar?
Re: B-1 Header gaskets???? Is there such a beast??? [Re: sg66mopar] #670453
04/15/10 08:24 PM
04/15/10 08:24 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
Thats funny, Flatout makes a gasket that fits the B-1 Flange that Koffels sells. We are a dealer and have been using them for a while. Call us if you need some.
Re: B-1 Header gaskets???? Is there such a beast??? [Re: PETE@BESTMACHINE] #670454
04/16/10 01:33 AM
04/16/10 01:33 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I use the Flat out gaskets from Pete@Best machine. They work great.
Re: B-1 Header gaskets???? Is there such a beast??? [Re: camastomcat] #670455
04/16/10 10:08 AM
04/16/10 10:08 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I use silicone. Have seen the flat out gaskets you might also find them as SCE, they make a really nice valve cover gasket.
Re: B-1 Header gaskets???? Is there such a beast??? [Re: Al_Alguire] #670456
04/16/10 11:30 AM
04/16/10 11:30 AM
NW PA
NW PA
FOr those that use silicone..... do you put it on & then install???? Or let it set up for a certian amount of time??
V10
Re: B-1 Header gaskets???? Is there such a beast??? [Re: V10nacuda] #670457
04/17/10 12:08 AM
04/17/10 12:08 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I let mine skin up before install. But in a tube car it is a pretty simple install.
