A-body TTI headers & Z-bar #659946
04/03/10 02:46 PM
04/03/10 02:46 PM
Lake Orion, MI
goldduster318 Offline OP
Lake Orion, MI
I'm looking to install some TTI headers on my 70 Duster and want to use the mechanical clutch linkage for the 4-speed. TTI says modifications may be required to the factory z-bar. Has anyone run into this? Any Z-bars that are off the shelf that fit better than others (Brewer's, etc).
Any pictures? What if any issues have you run into?
Thanks for the help!
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: A-body TTI headers & Z-bar [Re: goldduster318] #659947
04/03/10 03:41 PM
04/03/10 03:41 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
I went through this last summer. I put TTIs on my 70 340 Dart and I had a problem with the z-bar hitting one of the header tubes. I had to take it off and have it modified for clearance.
Re: A-body TTI headers & Z-bar [Re: 6PAX] #659948
04/03/10 04:16 PM
04/03/10 04:16 PM
Lake Orion, MI
Lake Orion, MI
when you say modified, are you saying just grind a little off OR is it more like cut the lug off and re-weld it in a different spot?
Re: A-body TTI headers & Z-bar [Re: goldduster318] #659949
04/03/10 04:26 PM
04/03/10 04:26 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
TTI sells the z-bar your looking for its about $100, or you can modify your z-bar.
Re: A-body TTI headers & Z-bar [Re: JeffC] #659950
04/03/10 04:28 PM
04/03/10 04:28 PM
Lake Orion, MI
Lake Orion, MI
I thought that Z-bar was for big block only applications based on the ball stud mount they call out (they use the brewer's number for big blocks)
Re: A-body TTI headers & Z-bar [Re: JeffC] #659951
04/03/10 04:32 PM
04/03/10 04:32 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I cut the downleg off and move it.
That one that tti sells looks like an abomination if used on a SB car. You don't have to move it much. Good luck putting a S bend in it like tti suggested after they said they never heard of such a problem.
total [Email]cr@p[/Email] for as much as they cost.
Re: A-body TTI headers & Z-bar [Re: goldduster318] #659952
04/03/10 04:49 PM
04/03/10 04:49 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
Yep thats for a big block nevermind.
Re: A-body TTI headers & Z-bar [Re: JeffC] #659953
04/03/10 10:59 PM
04/03/10 10:59 PM
Lake Orion, MI
Lake Orion, MI
So you just cut it off and move it over a bit? Sounds easy enough. Pictures would be very helpful though!
Re: A-body TTI headers & Z-bar [Re: goldduster318] #659954
04/04/10 01:17 AM
04/04/10 01:17 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Maybe I got lucky. My 360 4sp Duster has TTI headers and all I had to do was bend the lower leg toward the block a little and everything fit fine. If there is a problem with yours, maybe a mod at the ball swivel at the bellhousing end could help.
Re: A-body TTI headers & Z-bar [Re: Kern Dog] #659955
04/06/10 06:38 AM
04/06/10 06:38 AM
Gilbertsville, PA 19525
P
Pntastar69 Offline
Pntastar69  Offline
P
Had to grind a little off the bottom and give it a slight bend to clear the header tube. Had the z-bar in n out numerous times til I got it just right.
