A-body TTI headers & Z-bar
#659946
04/03/10 02:46 PM
04/03/10 02:46 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I'm looking to install some TTI headers on my 70 Duster and want to use the mechanical clutch linkage for the 4-speed. TTI says modifications may be required to the factory z-bar. Has anyone run into this? Any Z-bars that are off the shelf that fit better than others (Brewer's, etc).
Any pictures? What if any issues have you run into?
Thanks for the help!
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: A-body TTI headers & Z-bar
[Re: 6PAX]
#659948
04/03/10 04:16 PM
04/03/10 04:16 PM
goldduster318
Lake Orion, MI
when you say modified, are you saying just grind a little off OR is it more like cut the lug off and re-weld it in a different spot?
[Re: JeffC]
#659950
04/03/10 04:28 PM
04/03/10 04:28 PM
goldduster318
Lake Orion, MI
I thought that Z-bar was for big block only applications based on the ball stud mount they call out (they use the brewer's number for big blocks)
[Re: goldduster318]
#659952
04/03/10 04:49 PM
04/03/10 04:49 PM
Posts: 1,249 Las Vegas
JeffC
Las Vegas
Yep thats for a big block nevermind.
[Re: JeffC]
#659953
04/03/10 10:59 PM
04/03/10 10:59 PM
goldduster318
Lake Orion, MI
So you just cut it off and move it over a bit? Sounds easy enough. Pictures would be very helpful though!
