Re: Eddy purchase
[Re: j3wbagell]
#651091
03/25/10 05:11 PM
03/25/10 05:11 PM
Posts: 15,487 Florida
scratchnfotraction
the mopar throttle adaptor for the eddy carb or a holley mopar throttle adaptor if you go holly maybe some studs/bolts and a 4-hole spacer 1" should do for a spacer
Re: Eddy purchase
[Re: scratchnfotraction]
#651092
03/25/10 05:23 PM
03/25/10 05:23 PM
Posts: 149 Cen Fla
j3wbagell
Cen Fla
ewww yikes, do i have to take it apart to install that?
I'll be using Summit i guess, if anyone knows the part name/numbers.
Re: Eddy purchase
[Re: j3wbagell]
#651093
03/25/10 05:26 PM
03/25/10 05:26 PM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Easy bolt-on deal. The Eddy 750s have a bad rap. I still prefer that style carb over a Holley for a street car.
Re: Eddy purchase
[Re: j3wbagell]
#651095
03/25/10 06:34 PM
03/25/10 06:34 PM
scratchnfotraction
thats a good carb for what you want the adaptor bolts on to the lever with 2 bolts may need an adaptor to go from the squarebore carb flange to spredbore intake also or what I did.. I used a holley 650 spredbore manual dble pumper on my 440 to bolt on to the stock 440 spredbore intake or pop for a matching intake along with the new carb
Re: Eddy purchase
#651097
03/25/10 06:45 PM
03/25/10 06:45 PM
Posts: 149 Cen Fla
j3wbagell
Cen Fla
i was thinkin bout the LD but mom is giving me an advance as it is so where ever i can save money i will. Grants don't come in till the start of the semester so ill have to manage for now. Ive heard i can use a gasket for the bore change, anyone have a positive answer on that? adapter?????? or NUMBER 2
