Eddy purchase #651090
03/25/10 05:08 PM
03/25/10 05:08 PM
Cen Fla
j3wbagell Offline OP
Cen Fla
Well i've finally decided to give up on getting my current carb to work, im getting 3k in grants so i might as well just buy a new one since i have prepaid college already.
Is there anything else i need to purchase other than the carburetor itself?
Re: Eddy purchase [Re: j3wbagell] #651091
03/25/10 05:11 PM
03/25/10 05:11 PM
scratchnfotraction Offline
the mopar throttle adaptor for the eddy carb
or a holley mopar throttle adaptor if you go holly
maybe some studs/bolts and a 4-hole spacer 1" should do for a spacer
Re: Eddy purchase [Re: scratchnfotraction] #651092
03/25/10 05:23 PM
03/25/10 05:23 PM
Cen Fla
Cen Fla
ewww yikes, do i have to take it apart to install that?
I'll be using Summit i guess, if anyone knows the part name/numbers.
Re: Eddy purchase [Re: j3wbagell] #651093
03/25/10 05:26 PM
03/25/10 05:26 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Easy bolt-on deal.
The Eddy 750s have a bad rap. I still prefer that style carb over a Holley for a street car.
- Stu Harmon
Re: Eddy purchase [Re: feets] #651094
03/25/10 05:41 PM
03/25/10 05:41 PM
Cen Fla
Cen Fla
I have a 318 so 750 might be a little much idk i have a 800 on now, I was planning on rolling with a 1405, 600cfm and a manual choke. Any suggestions?
Re: Eddy purchase [Re: j3wbagell] #651095
03/25/10 06:34 PM
03/25/10 06:34 PM
thats a good carb for what you want
the adaptor bolts on to the lever with 2 bolts
may need an adaptor to go from the squarebore carb flange to spredbore intake also
or what I did..
I used a holley 650 spredbore manual dble pumper on my 440 to bolt on to the stock 440 spredbore intake
or pop for a matching intake along with the new carb
Re: Eddy purchase [Re: j3wbagell] #651096
03/25/10 06:37 PM
03/25/10 06:37 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
get the Holley.
Re: Eddy purchase [Re: scratchnfotraction] #651097
03/25/10 06:45 PM
03/25/10 06:45 PM
Cen Fla
Cen Fla
i was thinkin bout the LD but mom is giving me an advance as it is so where ever i can save money i will. Grants don't come in till the start of the semester so ill have to manage for now.
Ive heard i can use a gasket for the bore change, anyone have a positive answer on that?
adapter??????
or
NUMBER 2
Re: Eddy purchase [Re: j3wbagell] #651098
03/25/10 07:32 PM
03/25/10 07:32 PM
Howell, Michigan
Hemidavey Online work
Hemidavey  Online Work
Howell, Michigan
life may be better with a Holley
Re: Eddy purchase [Re: Hemidavey] #651099
03/25/10 07:45 PM
03/25/10 07:45 PM
Cen Fla
Cen Fla
I have a stock 318 with i think a cam
Name the best carb, preferably before 9 so i can beat the shipping timer. Anything
Re: Eddy purchase [Re: j3wbagell] #651100
03/25/10 07:57 PM
03/25/10 07:57 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
The 600 Eddy will be fine. Nice easy carb usually run fine out of the box. Just set the A/F mixture and idle setting. Drive it. Holley is a better all out performence carb if you don't mind constantly tweaking it. The Eddy is more street freindly, set it forget it.
Re: Eddy purchase [Re: Dougsmopars] #651101
03/25/10 08:01 PM
03/25/10 08:01 PM
New Hampshire
n_bogie1984 Offline
n_bogie1984  Offline
New Hampshire
eddys are hit and miss, you either have a good one or one thats junk, i myself have never had a issue with a holley.
Re: Eddy purchase [Re: Dougsmopars] #651102
03/25/10 08:03 PM
03/25/10 08:03 PM
canada
jneuf Offline
jneuf  Offline
canada
I put an edelbrock 1406 (electric choke 600 cfm) carb on my 318 last year...I bought it used, so I had to tinker with it a little to get it to run right, but now it runs great. Also, its EASY to tune...if I could figure it out, anyone can...
Re: Eddy purchase [Re: j3wbagell] #651103
03/25/10 08:43 PM
03/25/10 08:43 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
Buy a used Holley ( you can get a 600 cfm for $50) take it to a carb shop have it rebuilt and set up to run correctly on you car. I'll bet you will have a great running carb and spend less than a new edlepuke that's not setup to run on your motor.
Re: Eddy purchase [Re: Boise Chall] #651104
03/25/10 09:42 PM
03/25/10 09:42 PM
use the adaptor thats in the first link,the open one IMO
either carb
Re: Eddy purchase [Re: scratchnfotraction] #651105
03/26/10 12:14 AM
03/26/10 12:14 AM
Cen Fla
Cen Fla
Welp i went with the 1405 as planned, however after looking at the applications tab i realized the second adapter was the right choice.
It came with a free air filter so im excited to get er on there. Kicked it up to 2nd day for gigs, heres to hoping it all falls through.
Re: Eddy purchase [Re: scratchnfotraction] #651106
03/26/10 12:16 AM
03/26/10 12:16 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Could also buy a prebuilt thermoquad from demonsizzler aka thermoquads.com I'm sure setting one up for a stock 318 would be a snap for him and he should be able to have it tuned right out of the box. If you don't like that idea, then I'd suggest an edelbrock 600 with a spreadbore adapter plate. I've got a holley 650dp I'm trying to sell but I don't think that carb would be the best choice for a stock 318.
Re: Eddy purchase [Re: DaytonaTurbo] #651107
03/26/10 12:23 AM
03/26/10 12:23 AM
Cen Fla
Cen Fla
I really should have gone with the TQ but i was to lazzzy i guess,
