Page 2 of 6 1 2 3 4 5 6
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Brian Hafliger] #637734
03/12/10 07:10 PM
03/12/10 07:10 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Are they magnum or LA heads? Will they work with dome top pistons? I am impressed with the results you got.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: RHS headed 410 PUMP GAS UPDATE! [Re: S/ST 3040] #637735
03/12/10 07:16 PM
03/12/10 07:16 PM
gregsdart Offline
gregsdart  Offline
Hey Brian, great job on the motor. Tens on a juice cam smallblock is hauling the mail in my book.
Re: RHS headed 410 PUMP GAS UPDATE! [Re: gregsdart] #637736
03/12/10 07:51 PM
03/12/10 07:51 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Really nice job! Brian!!
WIZE
In Car:
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Streetwize] #637737
03/12/10 07:54 PM
03/12/10 07:54 PM
Q
Quicktree Offline
Quicktree  Offline
Q
very nice , the 60' times are way better than the ET shows though.
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Brian Hafliger] #637738
03/12/10 08:58 PM
03/12/10 08:58 PM
Portland, Or.
Bee4spd Offline
Bee4spd  Offline
Portland, Or.
Awesome running combo. Out of curiosity, what kind of vacuum did it pull at idle?
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Quicktree] #637739
03/12/10 09:02 PM
03/12/10 09:02 PM
SoCal.
MoparMark Offline
MoparMark  Offline
SoCal.
Brian, just sent you the pics from last night for a little bit of proof and to answer all the replies, yes the car ran great for a "low power pump gas street motor". So, If anyone is looking for an inexpensive street engine with great potential, give Brian a call.
Re: RHS headed 410 PUMP GAS UPDATE! [Re: MoparMark] #637740
03/12/10 09:25 PM
03/12/10 09:25 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
I am going to let you say it is a 10 second car. That happens to be EXACTLY what the Valiant runs at Irwindale. And , guess what...........
SRT DEMON ONE SEAT
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Ron Silva] #637741
03/12/10 09:29 PM
03/12/10 09:29 PM
USA
Ron Silva Offline
Ron Silva  Offline
USA
Oh yeah, that "IS" a great Motor. I would seriously consider buying one if I was in need.
Great Job Brian!
SRT DEMON ONE SEAT
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Ron Silva] #637742
03/12/10 09:44 PM
03/12/10 09:44 PM
ohio
HEMIDARTS Offline
HEMIDARTS  Offline
ohio
sounds real nice!!
Re: RHS headed 410 PUMP GAS UPDATE! [Re: HEMIDARTS] #637743
03/12/10 10:38 PM
03/12/10 10:38 PM
S.E. Minnesota
gtsdude Online happy
gtsdude  Online Happy
S.E. Minnesota
That sounds like something I would be interested in myself. Those heads work with the old 340 stock replacement pistons?
Re: RHS headed 410 PUMP GAS UPDATE! [Re: gtsdude] #637744
03/12/10 10:49 PM
03/12/10 10:49 PM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
the 6.90's and 7flats wouldn't be too impressive for a 410 UNTIL you factor in the unported iron heads and a hyd. flat tappet cam and pump gas. NOW that's impressive!
Re: RHS headed 410 PUMP GAS UPDATE! [Re: tjmarcus1] #637745
03/12/10 10:55 PM
03/12/10 10:55 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
Rock on Brian! That is awesome to hear!!!!
Re: RHS headed 410 PUMP GAS UPDATE! [Re: StrokerAspen] #637746
03/12/10 11:11 PM
03/12/10 11:11 PM
SoCal
Brian Hafliger Offline OP
SoCal
Thank you guys very much! It means alot that you can see what we did on a somewhat tight budget considering the peformance of the engine.
Before we ever had a dyno, we built plenty of powerful street and track engines. How an engine runs down the track is MUCH more important than any DYNO #!!
This engine will be for sale soon too, if anyone is interested just PM me.
The heads are LA X heads, hughes shaft rockers. I did upgrade the pushrods to .058 wall 3/8 hollow rods over the hughes supplied 5/16 solid for a tech article about pushrod oiling. I used AMC hyd. lifters and took that time to reinstall the dual plane intake for the drag strip runs.
I'll be running it again on the dyno for a few tests soon and I'll post that info then.
I'm working on uploading and resizing pics and movies so it's going to be late before I get them on here but they are good pics and movies...thanks to Rob, Mark and Phil for the help and laughs!!
Like I said before, I'm not lighting the world on fire or anything but we now have good proof that our RHS heads can make very good power at a reasonable price.
I'd say that's pretty good for the ole sb mopar!!
I think the vacume at idle was around 7" at 1000rpm, but I set the idle in the car at 1200 and it liked that much better so at that rpm I'd say maybe 8.5"...
Brian Hafliger
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Brian Hafliger] #637747
03/13/10 12:02 AM
03/13/10 12:02 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
I might add that that cam (XE295HL) had excellent street manners in my 340. It would idle @900rpm all day long. A 10 sec street engine.....schweeet
Yeah, it's got a smallblock.
Re: RHS headed 410 PUMP GAS UPDATE! [Re: 340B5] #637748
03/13/10 12:34 AM
03/13/10 12:34 AM
SoCal
SoCal
Some pics courtesey of Mark:
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Brian Hafliger] #637749
03/13/10 12:34 AM
03/13/10 12:34 AM
SoCal
SoCal
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Brian Hafliger] #637750
03/13/10 12:35 AM
03/13/10 12:35 AM
SoCal
SoCal
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Brian Hafliger] #637751
03/13/10 12:35 AM
03/13/10 12:35 AM
SoCal
SoCal
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Brian Hafliger] #637752
03/13/10 12:36 AM
03/13/10 12:36 AM
SoCal
SoCal
My G'd out gangsta lean...LOL!!
Re: RHS headed 410 PUMP GAS UPDATE! [Re: Brian Hafliger] #637753
03/13/10 12:37 AM
03/13/10 12:37 AM
SoCal
SoCal
