overfilled?
#626594
02/28/10 10:38 AM
02/28/10 10:38 AM
Posts: 761 KY
juicedcuda
KY
What can happen when the transmission is over filled? TF-727.
1970 Plymouth 'Cuda
1970 Plum Crazy "Gold Duster"
1973 Gold Duster
Re: overfilled?
[Re: Cab_Burge]
#626599
02/28/10 03:41 PM
02/28/10 03:41 PM
my 63 plymouth is very sensitive to overfill, it seems to dump and dump out the front pump vent if it gets 1/2 quart overfilled. as soon as it gets hot it doesnt stop puking out.
Re: overfilled?
#626601
02/28/10 05:17 PM
02/28/10 05:17 PM
Quicktree
you shouldn't have a front pump vent
Re: overfilled?
[Re: dusturbd340W5]
#626602
02/28/10 05:23 PM
02/28/10 05:23 PM
Posts: 6,446 NJ-USA
HPMike
NJ-USA
My thoughts: Excessive windage in the rotating parts, which could aerate the fluid. The normal fill is about the bottom of the valve body, so it doesn't take much higher to reach the rotating parts. And aerated fluid could be bad news.
One quart of over fill can kill most automatic trans in less tha a 100 mile trip at 60+ MPH way better to be one pint low than one cup overfilled
sorry I have been in the trans buisness 25 Plus years and I call BS on this one a quart overfilled will do nothing to a unit but maybe a little leak will not damage the unit in any way I have driven my personal cars overfilled for over a 100k with 0 problems. There are a number of units the ATSG wants you to overfill.
From another trans guy, I agree.
Yes, you wouldn't want any more than you need, but the worst that will usually happen, is that the unit will vent.
While it doesn't necessarily apply to this thread, many of the FWD production vehicles actually operated better with a quart overfill. The old GM 440T4(before they became 4T60's) and AXOD's were some of the units that worked better and lasted longer when overfilled.
MB
Re: overfilled?
[Re: Quicktree]
#626604
02/28/10 06:19 PM
02/28/10 06:19 PM
it was on my list of to do's but forgot to change it over to the rear style vent. only happens on my 63 but it will get changed when the tranny comes back out for a freshen up and a new billet steel drum.
Re: overfilled?
[Re: dusturbd340W5]
#626605
02/28/10 08:30 PM
02/28/10 08:30 PM
Posts: 16,928 NC
440Jim
NC
sorry I have been in the trans buisness 25 Plus years and I call BS on this one a quart overfilled will do nothing to a unit...
Help me understand. If overfilling will do nothing, why do people's trans vent out the TOP when they do it, and that is about 5 gallons higher then the fluid level?
Just trying to understand. And this post is about a TF-727, so leave the irrelavant stuff out. You are a professional, no?
As you can see, in a TF727, the front drum is very close to the recommended fluid level (near the case/pan line).
Re: overfilled?
[Re: nss guy]
#626607
02/28/10 09:11 PM
02/28/10 09:11 PM
Speaking of over filling, remind me or us how many quarts to fill when changing the filter with the mopar deep steel pan on a 727? I just dropped the pan and changed the filter, how many quarts do I use? The reason for the question is I changed to a locking dipstick and not sure if the marks will be correct. thanks, Jim
jim it all depends on the size of your converter. 8" converter is around 6.5 quarts with a deep pan.
Re: overfilled?
#626609
02/28/10 09:30 PM
02/28/10 09:30 PM
Posts: 1,443 central ohio
nss guy
central ohio
8" ATI converter
