overfilled? #626594
02/28/10 10:38 AM
02/28/10 10:38 AM
KY
juicedcuda Offline OP
KY
What can happen when the transmission is over filled? TF-727.
1970 Plymouth 'Cuda 1970 Plum Crazy "Gold Duster" 1973 Gold Duster
Re: overfilled? [Re: juicedcuda] #626595
02/28/10 10:41 AM
02/28/10 10:41 AM
Q
Quicktree Offline
Quicktree  Offline
Q
it will leak
Re: overfilled? [Re: juicedcuda] #626596
02/28/10 10:57 AM
02/28/10 10:57 AM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
It will push it out the vent.
Re: overfilled? [Re: juicedcuda] #626597
02/28/10 11:13 AM
02/28/10 11:13 AM
NC
440Jim Offline
440Jim  Offline
NC
My thoughts:
Excessive windage in the rotating parts, which could aerate the fluid. The normal fill is about the bottom of the valve body, so it doesn't take much higher to reach the rotating parts. And aerated fluid could be bad news.
Re: overfilled? [Re: 440Jim] #626598
02/28/10 02:58 PM
02/28/10 02:58 PM
My thoughts:
One quart of over fill can kill most automatic trans in less tha a 100 mile trip at 60+ MPH way better to be one pint low than one cup overfilled
Re: overfilled? [Re: Cab_Burge] #626599
02/28/10 03:41 PM
02/28/10 03:41 PM
my 63 plymouth is very sensitive to overfill, it seems to dump and dump out the front pump vent if it gets 1/2 quart overfilled.
as soon as it gets hot it doesnt stop puking out.
Re: overfilled? [Re: Cab_Burge] #626600
02/28/10 05:15 PM
02/28/10 05:15 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
My thoughts:
sorry I have been in the trans buisness 25 Plus years and I call BS on this one a quart overfilled will do nothing to a unit but maybe a little leak will not damage the unit in any way I have driven my personal cars overfilled for over a 100k with 0 problems.
There are a number of units the ATSG wants you to overfill.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: overfilled? #626601
02/28/10 05:17 PM
02/28/10 05:17 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you shouldn't have a front pump vent
Re: overfilled? [Re: dusturbd340W5] #626602
02/28/10 05:23 PM
02/28/10 05:23 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
My thoughts:
From another trans guy, I agree.
Yes, you wouldn't want any more than you need, but the worst that will usually happen, is that the unit will vent.
While it doesn't necessarily apply to this thread, many of the FWD production vehicles actually operated better with a quart overfill. The old GM 440T4(before they became 4T60's) and AXOD's were some of the units that worked better and lasted longer when overfilled.
MB
Re: overfilled? [Re: HPMike] #626603
02/28/10 05:35 PM
02/28/10 05:35 PM
Kissimmee Fl.
Kissimmee Fl.
My thoughts:
MB
thats correct those are some of the units ATSG wanted overfilled along with units like the E40D
Re: overfilled? [Re: Quicktree] #626604
02/28/10 06:19 PM
02/28/10 06:19 PM
it was on my list of to do's but forgot to change it over to the rear style vent.
only happens on my 63 but it will get changed when the tranny comes back out for a freshen up and a new billet steel drum.
Re: overfilled? [Re: dusturbd340W5] #626605
02/28/10 08:30 PM
02/28/10 08:30 PM
NC
440Jim Offline
440Jim  Offline
NC
sorry I have been in the trans buisness 25 Plus years and I call BS on this one a quart overfilled will do nothing to a unit...
Help me understand. If overfilling will do nothing, why do people's trans vent out the TOP when they do it, and that is about 5 gallons higher then the fluid level?
Just trying to understand. And this post is about a TF-727, so leave the irrelavant stuff out. You are a professional, no?
As you can see, in a TF727, the front drum is very close to the recommended fluid level (near the case/pan line).
Re: overfilled? [Re: 440Jim] #626606
02/28/10 09:08 PM
02/28/10 09:08 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Speaking of over filling, remind me or us how many quarts to fill when changing the filter with the mopar deep steel pan on a 727? I just dropped the pan and changed the filter, how many quarts do I use? The reason for the question is I changed to a locking dipstick and not sure if the marks will be correct.
thanks,
Re: overfilled? [Re: nss guy] #626607
02/28/10 09:11 PM
02/28/10 09:11 PM
thanks,
jim it all depends on the size of your converter.
8" converter is around 6.5 quarts with a deep pan.
Re: overfilled? [Re: 440Jim] #626608
02/28/10 09:14 PM
02/28/10 09:14 PM
Kissimmee Fl.
Kissimmee Fl.
if you overfill it enough it will vent but 1 quart isn't that much normally to get a 727 to vent it will have to be more than 1 quart.
Re: overfilled? #626609
02/28/10 09:30 PM
02/28/10 09:30 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
thanks,
8" ATI converter
Re: overfilled? [Re: 440Jim] #626610
02/28/10 09:48 PM
02/28/10 09:48 PM
NJ-USA
HPMike Offline
HPMike  Offline
NJ-USA
I don't think anyone would argue that you should fill to the proper level and have no more fluid than you absolutely need. Let's face it, in a drag race environment, most want the least amount of fluids to properly get the job done. Even if you didn't cause any damage to the unit, you certainly don't want to be venting ATF all over the track.
But as far as any catastrophic damage from being one quart overfull? I have never seen it. Burn the unit up in 100 miles? I never seen it.
My .02, but then again, what do I know?
MB
Re: overfilled? [Re: HPMike] #626611
03/01/10 01:41 AM
03/01/10 01:41 AM
Mike, I lived in the Mojave desert at the top of the Cajon pas, I knew most of the better tranny shop owners in that area thru racing. They told me on more than one occasion that most of thier business, especially in the summer, was from over filled trans missions and lack of changing the fluids. I have seen cars catch on fire coming up the Cajon pass ue to the trans. being overheated and venting fluid onto the exhaust system these where usually people on thier way to Las Vegas doing 70 to 80 MPH uphill with the air conditioning on in the middle of the afternoon and not looking in there rear view mirrors
