calculating compression ratio with engine together.
#622933
02/24/10 04:04 PM
02/24/10 04:04 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
Kinda curious. Is it possible to calculate compression ratio with the engine together. It would seem to me it wouldnt be too hard using a combustion chamber volume and p s i during compression stroke. Possible? Thanks. Cheers. pat
Re: calculating compression ratio with engine together.
[Re: Pat_Whalen]
#622934
02/24/10 06:31 PM
02/24/10 06:31 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
If you know or have access to the #'s you can plug them in HERE
[Re: WILD BILL]
#622935
02/24/10 07:02 PM
02/24/10 07:02 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
Bill: The one number I'm missing, which I know is critical, is how deep in the hole the pistons are. That's why I was wondering if it can be done via some math and knowing the compression value of the cylinder itself at TDC.
[Re: DaytonaTurbo]
#622937
02/24/10 07:10 PM
02/24/10 07:10 PM
WILD BILL
BROOK PARK, OH
Sorry but it sounds like if you wanna know your gonna need to pull a head
[Re: AndyF]
#622939
02/24/10 10:25 PM
02/24/10 10:25 PM
Pat_Whalen
super gas
super gas
Mesa, AZ
If the engine is on a stand you can measure the volume at BDC and TDC.
Engine is on a stand. How do I go about doing this? Same way to measure volume of a cylinder head? Thanks for renewing my hope, Andy.
[Re: Pat_Whalen]
#622941
02/25/10 10:55 AM
02/25/10 10:55 AM
RapidRobert
On the stand I'd put a fair amt of (as suggested) ATF in there then turn it over several times to coat the walls etc then turn it upside down/drain it then turn it right side up & at BDC fill it & record the amt then upside down & drain it then right side up & turn to TDC then fill it & record the amt & do the math. Pre coating everything before you calculate will give you significantly more accurate reading I would think because if you dont, the amt left over that is coating the surfaces from the 1st quantity is going to skew the 2nd reading giving you a false reading of more or less CR depending on if you fill @BDC or TDC 1st. How much I do not know but I think w a bit more effort (to precoat) that you can end up w a pretty accurate reading on what you got.
[Re: RapidRobert]
#622942
02/25/10 03:47 PM
02/25/10 03:47 PM
Posts: 8,884 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
NO, NO , NO , NO - do NOT precoat the cylinder - that will definately skew the numbers. Besides, all that filling and draining is unnecessary!
Do as Andy said.
Pull the rockers so the valves don't open. Flip the motor so the plug hole is up and level. Bring the piston to TDC, fill the cavity using a burrette (measuring in cc's). Record that volume. Bring the piston to BDC. Fill the rest of the bore using the burrette (this will take a LONG time 'cause burrette's hold surprisingly little). Record that volume and do the math. If you screw up, empty that cylinder and then do it again on a different cylinder so that any fluid residue doesn't skew the numbers.
[Re: Stanton]
#622943
02/25/10 04:15 PM
02/25/10 04:15 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Do as Andy said.
Why do you need to fill it twice?
Can't you calculate the cylinder volume?
Bore and stroke you know. You can calculate this with the info you already have.
- The area the piston is down, including the area to the first compression ring
- valve relieves
- piston dome
- chamber volume
are areas that you are unsure of and measured with the piston at TDC. Make sure to measure to the bottom of the Sparkplug threads and turn the motor on the stand so the bottom of the sparkplug is at the top of the chamber.
[Re: HealthServices]
#622944
02/25/10 05:05 PM
02/25/10 05:05 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
Do as Andy said.
- valve relieves
- piston dome
- chamber volume
How would you figure swept volume then? How would you know what volume is swept, from quench volume? You need to know the volume at TDC, then any other volume or point of referance..but how will you know at what point the piston is down..Thats why it would be simple to just do TDC, then BDC...this will tell you swept, then quench.. Thats all you need.
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Bob_Coomer]
#622946
02/25/10 05:46 PM
02/25/10 05:46 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Do as Andy said.
- valve relieves
- piston dome
- chamber volume
Compression Ratio = Uncompressed volume ÷ Compressed volume
Uncompressed volume = Displacement + Compressed volume
Displacement = (Bore ÷ 2) X (Bore ÷ 2) X 3.14 x Stroke x 16.387
16.387 is the number to convert cubic inches to cc's.
Compressed volume = the volume you measured at TDC.
Bring the piston to BDC. Fill the rest of the bore using the burrette ( this will take a LONG time 'cause burrette's hold surprisingly little).
Measuring the volume of the bore at BTC in addition to the volume at TDC just seems like a lot of extra work. With the bore and stroke you are just a couple clicks of the calculator from finding this value, just add the measurement from the TDC to it. Plus it's a big mess to clean up if you fill the bore at BTC afterwards.
#622947
02/25/10 05:47 PM
02/25/10 05:47 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
You're not ... the first check is the volume at TDC, then turn to BTC and fill the remainder for the second check. But it's only "filled" once.
[Re: 383man]
#622949
02/26/10 12:14 AM
02/26/10 12:14 AM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
How do you figure ??? You don't just flip the engine and dump the contents on the floor when you're done !!! You use your head and with some small hose or tubing you siphon the fluid out of the cylinder. Tilt the motor slightly and properly position the hose and it should get just about all the fluid out. Jeez !!!
#622951
02/26/10 08:46 AM
02/26/10 08:46 AM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
I don't care how you do it. I just offered some advice as how 'I' have done it. One thing I would like to know,,what is "BTC"?
If you like drag racing, support your local track.
