NO, NO , NO , NO - do NOT precoat the cylinder - that will definately skew the numbers. Besides, all that filling and draining is unnecessary!
Do as Andy said.
Pull the rockers so the valves don't open. Flip the motor so the plug hole is up and level. Bring the piston to TDC, fill the cavity using a burrette (measuring in cc's). Record that volume. Bring the piston to BDC. Fill the rest of the bore using the burrette (this will take a LONG time 'cause burrette's hold surprisingly little). Record that volume and do the math. If you screw up, empty that cylinder and then do it again on a different cylinder so that any fluid residue doesn't skew the numbers.
Why do you need to fill it twice?
Can't you calculate the cylinder volume?
Bore and stroke you know. You can calculate this with the info you already have.
  • The area the piston is down, including the area to the first compression ring
  • valve relieves
  • piston dome
  • chamber volume
are areas that you are unsure of and measured with the piston at TDC. Make sure to measure to the bottom of the Sparkplug threads and turn the motor on the stand so the bottom of the sparkplug is at the top of the chamber.
