Broken exhaust stud questions #622021
02/23/10 06:52 PM
02/23/10 06:52 PM
DFW
68RRFlyer Offline OP
DFW
I'm curious as to what studs enter the water jackets of the heads. 68 Charger R/T, 440 original engine. I have two broken studs; Passenger side, third up from the rear and on the Driver's side: furthest aft stud. I was able to drill out the passenger side one, and may have to chase the threads with a tap to get out the remaining bolt shards, but the driver's side aft is not going well. On top of that, my bolt extractor snapped off and now that's preventing me from drilling it out straight. Problems, problems. These were luckily broken before I removed them, so it wasn't my fault. But still, I have to fix them. I'm worried about coolant leaking out of the studs. Does that passenger one enter the water jacket in the head? Does the driver's side one as well? What sealer do I use on the bolts? I heard Great Stuff was the sealer of choice but wanted to ask around. Thanks guys.
Cheers
Re: Broken exhaust stud questions [Re: 68RRFlyer] #622022
02/23/10 07:52 PM
02/23/10 07:52 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
on a BB they all go into the water jacket,,,, on a SB only the end ones are wet,,
I am truckless..
Re: Broken exhaust stud questions [Re: 340SHORTY] #622023
02/24/10 10:35 AM
02/24/10 10:35 AM
scratchnfotraction Offline
broken ez out
all are wet on BB
good luck drilling
Re: Broken exhaust stud questions [Re: scratchnfotraction] #622024
02/25/10 12:49 AM
02/25/10 12:49 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
If you cant work the broken EZ out out of the head, you will need to pull the head and take it to a shop with an EDM machine to burn it out and then repair the damaged thresd.
Re: Broken exhaust stud questions [Re: 68RRFlyer] #622025
02/25/10 12:54 AM
02/25/10 12:54 AM
heat up the broken bolt extractor w the hot wrench then zap it w a shot of oxygen. It'll fly out of there back at you so fast you'll think it was too easy
Re: Broken exhaust stud questions [Re: sthemi] #622026
02/25/10 01:18 AM
02/25/10 01:18 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
It sounds like the heads gonna have to come off.
It'll be alot easier to work on getting out the broken extractor with the head off and on a workbench.
Re: Broken exhaust stud questions [Re: sthemi] #622027
02/25/10 02:10 AM
02/25/10 02:10 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
IF the guy doing the EDM process KNOWS what they are doing ... there is ZERO damage to the threads.
EDM is the best way to do this. And in case someone else is approaching the same situation ....USE a SQUARE EZ out.
Sears has them.
Re: Broken exhaust stud questions [Re: 68RRFlyer] #622028
02/25/10 09:33 AM
02/25/10 09:33 AM
pa.
dan9 Offline
dan9  Offline
pa.
I know the correct way is to remove the heads. I had the same problem once. I just took the exhaust manifold off and tapped it. I then put high heat epoxy in the hole and screwed a bolt into the manifold. Believe it or not the water leak stopped and i didn't have an exhaust leak. I know it wasn't proper but it worked for me.
