Re: Broken exhaust stud questions
[Re: 68RRFlyer]
#622022
02/23/10 07:52 PM
02/23/10 07:52 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
on a BB they all go into the water jacket,,,, on a SB only the end ones are wet,,
I am truckless..
[Re: sthemi]
#622027
02/25/10 02:10 AM
02/25/10 02:10 AM
Posts: 30,451 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
If you cant work the broken EZ out out of the head, you will need to pull the head and take it to a shop with an EDM machine to burn it out and then repair the damaged thresd.
IF the guy doing the EDM process KNOWS what they are doing ... there is ZERO damage to the threads.
EDM is the best way to do this. And in case someone else is approaching the same situation ....USE a SQUARE EZ out.
Sears has them.
