Been wondering, magnets in the pans... #619712
02/21/10 02:23 PM
02/21/10 02:23 PM
S.E. Conn
Hoof Hearted Offline OP
S.E. Conn
I keep reading these posts about guys with worn lobes on their cams or worn lifters, Does anyone other than me leave a magnet or two in both the oil pan and Trans pan?
In the oil pan I have two, one at the rear and one right next to the side drain plug and pickup.
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Been wondering, magnets in the pans... [Re: Hoof Hearted] #619713
02/21/10 03:13 PM
02/21/10 03:13 PM
A flat magnet in the trans pan definitely because you remove the pan regularly. A magnet tip on the eng oil pan drain plug works but I wonder that it's not large enough to be in contact w enough fluid to do much good. I'd like to epoxy a large chunk of speaker magnet in a corner inside of the pan & the only thing that would worry me is if it would keep the filings stuck to it until sometime in the distant future when I would be pulling the pan and I would think yes as some magnets have alot of pull and one of those round specialty ones that go around the filter I think is as good as you can get w this.
Re: Been wondering, magnets in the pans... [Re: RapidRobert] #619714
02/21/10 03:24 PM
02/21/10 03:24 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I like those Mopar big "donut" magnets.
Re: Been wondering, magnets in the pans... [Re: dOoC] #619715
02/21/10 03:56 PM
02/21/10 03:56 PM
Castlegar, BC, Canada
That AMC Guy Offline
Why not epoxy a magnet to the oil filter?
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Been wondering, magnets in the pans... [Re: That AMC Guy] #619716
02/21/10 04:03 PM
02/21/10 04:03 PM
I think those specialty ones that go on/around the filter have alot of area and alot of pull and with oil entering the small holes at the top of the filter all around the case then migrating inward thru the filtering material that you would want a magnet that goes all the way around the filter to affect as much oil as possible
Re: Been wondering, magnets in the pans... [Re: RapidRobert] #619717
02/21/10 05:03 PM
02/21/10 05:03 PM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
Take a mopar trans pan magnet and magnet it to the end of the oil filter. Then put a neat dab of black rtv covering the hole [in the magnet] to ensure it stays attached to the filter.
mopar part
3681601: magnet, auto trans pan, loose chip & metal collector all models/years
Re: Been wondering, magnets in the pans... [Re: ThermoQuad] #619718
02/21/10 07:03 PM
02/21/10 07:03 PM
S.E. Conn
S.E. Conn
mopar part
Am I wrong in assuming it's better to "catch" the debri in the pan with a magnet or two Before it gets sucked into the pickup tube then to the filter?
I just don't understand the magnet on the filter.
2005 300C Hemi
Re: Been wondering, magnets in the pans... [Re: Hoof Hearted] #619719
02/21/10 07:15 PM
02/21/10 07:15 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
MY THOUGHTS also !
ALSO .... if the BIGGER stuff gets into the screen .. it can restrict the flow.
Re: Been wondering, magnets in the pans... [Re: dOoC] #619720
02/21/10 11:16 PM
02/21/10 11:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Doesn't take much of a chip to lock up the oil pump, found that out the hard way. Be best to put a magnet in the pan, IMO.
Don't be the exception.
Re: Been wondering, magnets in the pans... [Re: Supercuda] #619721
02/22/10 12:11 AM
02/22/10 12:11 AM
Arlington, Texas
earlybee Offline
earlybee  Offline
Arlington, Texas
I used speaker magnets till I got these... http://cgi.ebay.com/10-PC-Super-Strong-N...=item1c0faf74a7 They WILL hurt you if your not carefull!DAMHIK
Re: Been wondering, magnets in the pans... [Re: Hoof Hearted] #619722
02/22/10 01:28 AM
02/22/10 01:28 AM
In the pan is the best, both is even better yet especially since the wrap around filter one can be easily switched when you change filters
Re: Been wondering, magnets in the pans... [Re: RapidRobert] #619723
02/22/10 12:45 PM
02/22/10 12:45 PM
Andrewh Offline
Andrewh  Offline
Why not epoxy a big magnet to the outside of the pan near the drain plug instead.
That way when you drain the oil you canpull the magnet. Then let teh crud flow out.
