Been wondering, magnets in the pans...
#619712
02/21/10 02:23 PM
02/21/10 02:23 PM
Posts: 2,179 S.E. Conn
Hoof Hearted
S.E. Conn
I keep reading these posts about guys with worn lobes on their cams or worn lifters, Does anyone other than me leave a magnet or two in both the oil pan and Trans pan?
In the oil pan I have two, one at the rear and one right next to the side drain plug and pickup.
2005 300C Hemi 2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Been wondering, magnets in the pans...
[Re: That AMC Guy]
#619716
02/21/10 04:03 PM
02/21/10 04:03 PM
RapidRobert
I think those specialty ones that go on/around the filter have alot of area and alot of pull and with oil entering the small holes at the top of the filter all around the case then migrating inward thru the filtering material that you would want a magnet that goes all the way around the filter to affect as much oil as possible
[Re: Hoof Hearted]
#619719
02/21/10 07:15 PM
02/21/10 07:15 PM
Posts: 30,447 Florida STAYcation
dOoC
The village idiot's idiot
Florida STAYcation
Am I wrong in assuming it's better to "catch" the debri in the pan with a magnet or two Before it gets sucked into the pickup tube then to the filter?
I just don't understand the magnet on the filter.
MY THOUGHTS also !
ALSO .... if the BIGGER stuff gets into the screen .. it can restrict the flow.
[Re: dOoC]
#619720
02/21/10 11:16 PM
02/21/10 11:16 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Doesn't take much of a chip to lock up the oil pump, found that out the hard way. Be best to put a magnet in the pan, IMO.
